  1. i want to convert a divx to a vcd but when i try to open it as the source it sas the file is unsupported, anyone have any ideas why?
    Aug 2001
    JERSEY
    you need to install some codecs try the krystal studio pac in the tool section
    Feb 2001
    Palmdale, CA
    need the codec or try demuxing the audio, sometimes the problem is the encoded audio.
    Feb 2001
    Palmdale, CA
    sorry, getting late here, another thing to try first is raising the vfw file and direct show priority up in tmpgenc enviroment option settings, this usually fixes the problem.
