Hello All
I'm new to this forum so please bear with me...
I'm trying to set-up the TV Card on my Medion MD8818 PC (got it this weekend). It is a Creatix SAA7131 card I believe and has an aerial input and a satellite input (F-plug). As hard as I try I cannot get the TV/AV source to switch to analog TV. It seems to be permanently stuck on DVB-S. The PC came with Cyberlink TV Enhance software with a TV settings shortcut that should allow you to change the TV/AV source. However I select analog and the app then closes and no change is made/savedI've tried everything I can think of - have also messed about in Media Center but no luck. Apparently the card can only be set to one of the tuner devices at any time, but it seems to be stuck on the wrong one. Any help would be really appreciated. Happy to change registry if anyone else has one of these and could let me know the required settings for analog TV.
Thanks in advance
Chris
Results 1 to 1 of 1
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
tv tuner card help!
By johanc in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2008, 07:02 -
'Creatix SAA7131 Triple Capture Device'.
By lmortiss in forum DVB / IPTVReplies: 10Last Post: 3rd Dec 2008, 17:17 -
Ref Creatix SAA7131, Triple Capture Device
By lmortiss in forum Capturing and VCRReplies: 0Last Post: 14th Apr 2008, 11:16 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
