Starting to fiddle with MPEG video now.
Delays' a hazzle. However, it strikes me as odd. I load this file in DGIdx, and demuxes to get proper sync delay in output filename. a123 Tc0 L2 2ch 44.1 224 DELAY 184ms, I get. However. When loading up the original mpg-file in VDubmod, and adding "-184" in the main stream, I get bad lip sync. However, 184 (+) seems to give me a much greater deal of sync. Are you supposed to use + for - (and vice versa) in this case? Are the delays opposite (one is video in condition to audio; whereas the other gives audio in condition to video). The other thing I could think of is that something is bugging here. Corrupt video header somehow? Sorry for the stupid question, if I'd had more .mpg example with different delays I'd investigate the answer by simple trial and error, asking seems the easiest way here tho.
Drop dead gorgeous!
Never mind my post. Happened to stumple on a MPEG1-video (an ancient A-teens musicvid) with a reported audio delay of 360ms. This was more easy to decide, loading in VDM and comparing delay flag "-360" w/ "+360" made it easy to see (what I'd expected to be appropriate from the beginning; before starting to doubt/go confuzed) that positive should stay positive; and thus negative -> negative. Sorry for stealing unnecessarily board-space.
Drop dead gorgeous! -
DGIndex makes Video out of sync with Audio - please help!
By VideoFanatic in forum Video ConversionReplies: 10Last Post: 16th Oct 2011, 16:53 -
Noob needs help understanding the basics!
By Tookie75 in forum Video ConversionReplies: 2Last Post: 22nd Sep 2010, 08:52 -
Basics
By Pechin in forum MacReplies: 2Last Post: 29th Mar 2008, 17:04 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07 -
VDubMod Audio Sync Problems, Help!
By blueprint in forum Newbie / General discussionsReplies: 21Last Post: 20th May 2007, 23:18
