Hi all,
I burn .avi movies to CDs using 'Nero'. Im using 'NERO' 6. There are newer versions of NERO but i like this old version because it is still sufficient enough to my works.
When it is writing .avi file to a disc using 'NERO 6' it doesn't need file to be manually converted using third party converter like 'Total Video Convertor'. NERO automatically encode the file and then write it to the disc, but i cannot merge a subtitle file(.srt) with NERO to a movie.
Early days I used 'Total Video Converter (TVC) ' to merge .srt file to .avi file. I just wanted to merge .srt file to .avi file and then write that file to a disc using NERO, but with TVC the .avi file is merged with .srt file while .avi file is being converted to another format like .mpeg(In latest versions of TVC we have option to select .srt file to be merged, then conversion and merge will take place at same time).
Now Im asking is there any way to merge .srt file to movie with NERO(in newer versions)?
because it will be very simple than using another tool like a video converter.
TVC is a very good option, but we need not any convertion since NERO doing encoding very well with good quality.
Thanks in advance,
Dilan Alex.
If you're writing an AVI as "VCD", then you are certainly converting.Originally Posted by dilanalex
Or do you mean you're writing the AVI as data to a CDR?
-- If there is a long processing time, you're converting. Just copying the AVI will take a couple of minutes.
Many players that play AVI files will read an SRT file with the same name (i.e. moviename.avi and moviename.srt) and use it if you put them both in the root directory.
How to hardcode .sup subtitle file to a mkv movie?
By CodeGEN in forum SubtitleReplies: 6Last Post: 13th Mar 2017, 04:24 -
DVDFab: Subtitle file won't merge with avi
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2009, 23:53 -
MKV Merge subtitle error
By zzyzx2 in forum SubtitleReplies: 2Last Post: 2nd Jun 2008, 00:44 -
Help how i can Merge subtitle with movie?
By WhitGer in forum SubtitleReplies: 0Last Post: 25th Mar 2008, 02:16 -
how to merge two .mpg movie files into one dvd file
By morefeus46 in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2007, 20:43
