Results 31 to 36 of 36
From what I can gather, the registry merge fix referred to in Doom9 (and Autogk faq) is to find "proxyoff.reg" in the path:
and double click on and 'merge' it into your registry.Code:C:\Program Files\AutoGK\VDubMod\aviproxy
I personally haven't had a need to do this, although I wonder if it is related to AuxSetup.exe / install handler?
Anyway, maybe others with a bit more knowledge can advise on this 'fix'? -
prolly...i have no idea how to merge a registry or something. i be sad
According to http://www.doom9.org/index.html?/virtualdub_procedures.htm under the heading 'Installing Frameserver support', the proxyon.reg is used for frameserving, and should be turned off after encoding.
Long time ago, I did use vdub for frameserving (DVD2AVI - vfapi - vdub - TMPGenc).
If somehow it has been enabled on your PC, the options to disable would be:
1. right click proxyoff.reg, select merge, or
2. double click proxyoff.reg, and click 'Yes' to the message "Are you sure you want to add the information...to the registry".
HOWEVER, I am no expert on this, and as it effectively edits your registry, maybe wait for others to offer comment on this and any possible side-effects before you try it. -
hmm...well i moved on...i downloaded drdivx, converted it to a divx and used tmpenc xpress 3.0 to convert to avi. so beyond using that method...i hope autogk still works for me when i convert other stuff...but i just noticed that when i tried to convert an entire ep of sfu from vob to avi using it that i got the same error message...i'm sad.
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Conversion and playback issues.
By tooham in forum Video ConversionReplies: 1Last Post: 17th Feb 2009, 10:18 -
Auto GK conversion error:
By sibaroochi in forum Video ConversionReplies: 1Last Post: 28th Jan 2009, 05:26
