so i wanted to rip the ending scene to the series finale of six feet under. i ripped that scene with dvd decrypter, and using auto gk version 2.55 to convert from vob to divx avi. but i get this error message, "video compression error: the source image format is not acceptable (error code -2)"
this has been happening more and more often when i want to convert a vob file...anyone know why this is happening? i really wanna convert this file. please help.![]()
Results 1 to 30 of 36
Are you setting the cropping and/or frame size yourself? Divx requires frame dimensions that are multiples of 4. Multiples of 8 are better. Multiples of 16 are most efficient. So, for example, Divx will refuse to compress 641x480 and 642x480. 644x480 should play on pretty much every player. 640x480 will give the best efficiency.
i never really touch the settings...for the resizing...i chose fixed 640...and i still get the same error message.
output resolution settings? its on auto now...i dunno what it picks...how do i find out?
I don't know, I don't use the program! Does it show you the Avs script it's going to use?
It's not a cropping/resizing issue. You haven't provided enough information, though, to figure out the problem. Please post the log. Since you said it's a DivX conversion, there's a good chance you're using a DivX codec more up-to-date than what AutoGK supports. Either switch to XviD or use an older DivX codec.
Do you have any DivX codec at all installed? It's not included with AutoGK. My first suggestion is to switch to using XviD to see if the encode completes.
i do have divx and xvid...divx latest version...xvid 1.2.1-04122008
i tried converting with xvid...same error message. -
That's the XviD 1.2.1 that's included with the latest ver 2.55 of AutoGK, isn't it?
Until you get this sorted out I'd suggest working with XviD. I'm not entirely sure whether or not AutoGK supports the DivX 6.x.x. Maybe it does, but I'm not positive. I'm pretty sure it doesn't support the version 7 of DivX. I would next suggest starting over. First uninstall your XviD in Add/Remove programs. I would next delete AutoGK and reinstall the ver 2.55 upgrade, including the included version of XviD. I know, it's not exactly what you wanted to hear, but many such problems have been fixed with a reinstall, and I'm not really sure what the problem is. And for a really obscure possible reason for the problem, read this thread:
http://forum.doom9.org/showthread.php?s=&threadid=51906 -
so i uninstalled xvid and autogk....reinstalled autogk...chose xvid output...and i get an error message. i try inputing the ifo...and i get the same error message as per usual. this is rather odd now. i was always able to do stuff like this before...and now i can't.....ugh!
Out of interest, does this occur when you encode for example a full length tv epsiode or movie, or only when the input is a small clip of say, less than 1 min?
well at the moment its for this 6min scene i want to convert...i havent converted a full length movie recently, but i have and no problem.
Could you try lowering the bitrate? The log suggest you are aiming at 150mg for the clip.
Try custom size much lower. -
Try putting the input and output into a different folder, for example: c:\temp\VTS_01_1.VOB
I'm unsure of the limit if any for xvid/divx, but at the moment your target bitrate is 3007kbps.
i have done that since the beginning. i almost never put it in the same folder as the input.
with the latest version of autogk how do i lower the bitrate? i dont see a setting for it.
Originally Posted by John-Paul -
What I meant was, put BOTH input and output into folder c:\temp
Reason: your current folder structure might have a problem. -
what does putting the input/output folder in a diff folder mean? i mean currently its in my documents. how would changing folders do anything?
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Conversion and playback issues.
By tooham in forum Video ConversionReplies: 1Last Post: 17th Feb 2009, 10:18 -
Auto GK conversion error:
By sibaroochi in forum Video ConversionReplies: 1Last Post: 28th Jan 2009, 05:26
