Anyone else have this problem?
Just downloaded DVD Slideshow GUI. Can easily create a slide show and publish in DVD format but when I attempt to add music to the same slideshow and then publish, all I get is a blank slideshow with a red border & some music playing. I've tried adding different mp3s and even wav files but I get the same result.
If anyone could help with this problem, it would be appreciated.
If you're running it under Vista, you need to right click the DVDslideshowGUI.exe file in the main folder of DSG and "Run as administrator..." or else Vista will not allow DSG to save temp files to your harddisk - which's something it does for a living
Am running XP.
The slideshow is perfectly fine when published without sound. It's just that if I add a .wav or .mp3 to it to get a little music and then publish, I get no pictures - just the music playing over a red border with black inside. I get this wether I publish to DVD or mpg. -
Are you using the latest version? Check link in sig. If you are I'm sorry to say that I'm not able to reproduce it here. It sounds like the temp settings-preview file(DVDsGUIProTemp.avs) is rendered instead of the actual dvdsguitemp.avs file. If you got music on your normal previews, then as a workaround you can export as .avs, load that file into Super and render it to mgp and finally use Gui for dvdauthor to author you dvd. Alternatively if you allready got GFD installed then try to export as .gfd from DSG and use that file in GFD.
I think I found that bug you mentioned - so I hope it's fixed in the 0.9.1.1 version.
Tin2tin -
Thanks Tin2tin,
It's working!!!
This program is the only freely available Photo Album to DVD I've found and it now works a treat.
Best Regards,
Daniel
DVD Slideshow GUI
By spike47 in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2012, 12:23 -
Server error when running Install of DVD Slideshow GUI
By ROGUTAH in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2012, 18:51 -
Slideshow GUI - Can I have a slide duration lower than 3 seconds?
By phoenix777 in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2011, 17:58 -
blank pause in slide show and when converting to wmv file
By nosliw in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2009, 12:44 -
DVD Slideshow GUI
By Tripodd in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 14:19
