New Toy need tips...
Sanyo xacti E1 - MP4 format
Need help with the settings for avidemux - the goal is to use it to cut down to clean clips and export those to AVI format for saving off and incorperation into larger projects. if there is another method for my goal i would welcome any and all suggestions.
here are the details:
On the Files produced by the camera Gspot Reports:
Video:
mp42: MP4 v2 [ISO 14496-14]
- avc1: MP4 Base w/ AVC ext [ISO 14496-12:2005]
Recommended Display Size: 640 x 480
Audio:
mp4a: MPEG-4 AAC LC
48000Hz 128 kb/s tot , stereo (2/0)
So in Avidemux
When i open a file i get the h.264 detected message and something about using b-frames as a reference. Do i say yes or no to that? assume loosing frame accuracy is bad so i assume "No" is the right response ?
Video = MEG-4 AVC(x264)
Under configure left all default settings - any advice on these?
Audio = ACE (LAVC)
Not sure about that one... under configure 128 bit
Filters - None/Stereo and 4800 resample
Are these the best settings? ... so far it all would seem to be working i just don't want to go down the road and find out i messed something up and have a pile of MP4's to reconvert.
Also looking for validation on the whole approach... i considered just using Corel Video Studio and editing native MP4's but the recompression thing and problems incorporate into other mostly avi based projects concerned me.
thanks in advance! let me know if this information is inadequate in any way to answer my questions.
~derek
if you are just looking to crop, then leave video and audio on copy and container to mp4. try the b frame thing both ways and see which works?
Tried that – leaving everything set to “copy” result was an avi file with the audio waaayyyy out of sync with the video.
For some reason I had to set the options above for it to output correctly.
Looking for Tried and Tested mp4 to mp2 settings for DVD
By AndyInBuffalo in forum ffmpegX general discussionReplies: 0Last Post: 7th Mar 2012, 12:42 -
Best Ripbot Settings for mp4 Blu Ray @ 12000Kbps
By sam103329 in forum Blu-ray RippingReplies: 10Last Post: 8th Mar 2011, 18:38 -
Mp4 encoding settings for ps3
By catracho2009 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2010, 00:20 -
Ripping HD DVDs to streaming MP4 - Best settings for Quality?
By martymars in forum Blu-ray RippingReplies: 15Last Post: 23rd Sep 2009, 16:53 -
Dvd to mp4 with Handbrake(pc settings question)
By ultraman36 in forum DVD RippingReplies: 0Last Post: 30th Dec 2008, 11:55
