Results 1 to 15 of 15
    Jun 2008
    Hey all.
    After googling, it seems as though the only way to have MP4 thumbnail previews is to add this reg fix to the registry:
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\.3gp\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    @="{c5a40261-cd64-4ccf-84cb-c394da41d590}"
    [HKEY_CLASSES_ROOT\.asf\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.avi\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.dmf\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.divx\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.flv\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mkv\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mp2\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mpv\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mpeg\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mpe\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.m1v\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.m2v\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mpg\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mp4\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.mov\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.rm\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.rmvb\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.vcr\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.wmv\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.m4v\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.cbr\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    [HKEY_CLASSES_ROOT\.cbz\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}]
    If MP4 files are the only files on my PC that don't have thumbnail previews, wouldn't I only need to add this to the registry?:
    [HKEY_CLASSES_ROOT\.mp4\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
    @=”{c5a40261-cd64-4ccf-84cb-c394da41d590}
    Any info and/or advice is appreciated.
    Nov 2002
    Let us know how it works.
    I found a regpatch a couple of months ago that was supposed to add thumbnail view for MKV and MP4 and after installing it, my computer crashed every time I tried to open a file or a program. There was no regfixpatch to undo the damage so I had to reinstall Windows since the OS had become unusable.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It was my understanding that Windows can create thumbnails for all files in which WMP is the default player and has the proper codecs for playback. As I don't use WMP as my media player and I don't use thumbnail view for my folders, I can't verify.
    Google is your Friend
    Jun 2008
    Thanks for the replies DarrellS and Krispy Kritter.
    Well, I haven't added the regfix yet. I'm still undecided on whether to add the regfix or convert the MP4 files to AVI files.
    Yea, I was wondering about that. I currently have the K-Lite Codec Pack installed on my comp. The default player for MP4 files is Media Player Classic (which was part of the K-Lite Codec Pack). I have tried with WMP11 as the default, but no luck with preview thumbnails either.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Try this:
    - Click Start -> Run -> type:
    regsvr32 shmedia.dll
    - Click OK
    - Reboot
    Jun 2008
    Try this:
    - Click OK
    - Reboot
    Thanks for the suggestion, but no luck. Only the MP4 files are currently absent of preview thumbnails.
  7. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    from a Google search:
    http://a8t8.spaces.live.com/blog/cns!2518DD508BB713E8!265.entry
    Jun 2008
    Yea, that was one of the first things that I tried. Unfortunately, I'm not sure if Explorer recognizes an MP4 file in order to utilize the Haali Media Splitter thumbnail extraction option.
    Nov 2002
    That's the guide I used the first time that left my computer unusable. Not sure why. I tried it again except I did not install the MKV registry patch and it showed the thumbnails just fine by setting Haali splitter to yes for thumbnails. I did not set the offset though.
    Since that worked, I got brave and installed the MP4 patch and now my MP4 thumbnails show up. I must've had something else installed before that was conflicting with the Haali splitter cause I could not do anything without Windows crashing.
    Jun 2008
    Yea, that's why I'm hesitate about installing a regpatch at this point. I'm wondering if there are any other options out there.
    Jun 2008
    Does anyone know how well the Pazera MP4 to AVI converter works? I've read a few reviews here and there, but wanted to get some other opinions and/or advice as well.
  12. I have a similar problem now, except it is affecting all IMAGE (not video) files. Can you tell me a registry hack that will fix this issue? I've already tried clearing the thumbnail cache, and all other non-registry-hack solutions that people have suggested.
  13. My app can play the first few seconds of all my video files and a lot lot more....
  14. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You don't need a "hack", you need to try and determine what caused it not to work.
    It would likely be much faster and easier to simply take the time and perform a fresh install of the OS.
  15. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Just for information to original quote... In additon to the normal shown, several others may be present represented by:
    @="{9DBD2C50-62AD-11D0-B806-00C04FD706EC}" PotPlayer
    @="{c5aec3ec-e812-4677-a9a7-4fee1f9aa000}" Icaros
    @="{c5a40261-cd64-4ccf-84cb-c394da41d590}" Normal Codec
    If an entry is present but different, you can google it and usually find out which program is stifling your thumbnails.
