Hello,
I use a Sony Handycam DCR-SR45 Handycam. When I shoot my home movies there isn't an option to turn off the built-in mic. I'd like to shoot some video without sound. Or is it possible to somehow remove the sound trac from the resulting MP3 files the camcorder creates? I use Nero to burn DVDs and can add background tracks to the video but when the video track in in the video file is there a way to disable the audio or remove it?
Thanks,
John
mp3 files? mp3 is just audio.
I'm pretty sure it captures in mpeg2. So try rename the file to video.mpg and then demultiplex it to video and audio files using for example tmpgenc(under file->mpeg tools->simple demultiplexer) or tsremux(open video file, just check the video track, choose the demux checkbox, start muxing). Import the new video file in nero -
Yes. Sorry about that. I meant mpeg2. I'll these tools. Are there any other tools anyone else can point me to?
Removing humming sound during talk
By AjnabiZ in forum AudioReplies: 14Last Post: 22nd Oct 2011, 19:14 -
Panasonic DMR-EA18 recording help needed. No sound in video playback.
By LegendaryGamer in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2010, 09:52 -
Avidemux -video silent after 8.57
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2010, 22:03 -
before I capture, is this 16mm strip silent or with sound?
By mazinz in forum Capturing and VCRReplies: 6Last Post: 4th Dec 2009, 02:09 -
FFmpeg - Removing commercial breaks from mpeg TV recording
By Chris_Smith in forum Video ConversionReplies: 0Last Post: 19th May 2009, 04:43
