Results 1 to 12 of 12
  1. my system is crashing every time when I open a video and I get this message
    If you google clvsd.ax you see that it's part of some of cyberlinks products like powerdvd. Try uninstall it. Or manually find the clvsd.ax and unregister it, see http://www.free-codecs.com/guides/How_to_install_uninstall_DLL_and_AX_files.htm .
  3. Originally Posted by Baldrick
    I tried searching it as described in the link, but ...
    Replace filename.ax with clvsd.ax.
  5. The advice in that link is terrible. You should never copy things into the system32 directory unless you absolutely have to (VfW codecs are examples - usually) and you know what you are doing.
    The advice should be to use the command:
    regsvr32 <full path to file>
    e.g., if clvsd.ax is installed in C:\Program Files\PowerDVD (I have no idea if it is) then in the Run... box, type:
    regsvr32 "C:\Program Files\PowerDVD\clvsd.ax"
    The quotes are important.
    John Miller
  6. I'm a Super Moderator johns0's Avatar
    canada
    I find that when you copy certain dll ax ocx files into system32 folders and register them then when you go to the folder the files are in windows will hang and you have to shut down the process,also trying to get into system32 folder to delete the file causes the folder to hang.
    This happens in vista and winxp.Best to uninstall and reinstall.
  7. I don't have power dvd installed on the computer.
  8. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Did you install any other Cyberlink product? Or a codec pack that might, for some reason, have included it (even though they're probably not supposed to)?
  9. Originally Posted by Ai Haibara
    I just have K-lite codec pack.
  10. Member SanderMan's Avatar
    Feb 2001
    Netherlands
    Codec packs are a bad idea. They often screw up systems. try to uninstall and install only the codecs you need or something like ffdshow.
    Feb 2004
    Australia
    Also part of "BoliGego Codec Manager" available at freecodecs.com
    Location could refer to
    C:\program files\cyberlink\shared files\videofilter\clvsd.ax
  12. Originally Posted by alintatoc
    End of story.
