Would it be a bad idea to convert two vids at once?
Would it take as long as it would to convert one at a time?
I have a 500Mhz processor if that's important...
it can be done. i have tried it but if memory is correct it took me longer.....
I wouldn't recomend it eventhough it can be done your taking a chance as it might cause errors in the mpeg. and you wont save anytime. you might think of batch encoding though(tell it to do several one after the other).
I have done it with no problems, but a much better option is batch encoding, just enter all your jobs and hit run, much easier and less taxing on your puter...Gary
It can be done (I used to do 4-5 encodings at once until I discovered the batching functions of TMPGEnc).
I strongly recommend batching, however, first save all your encodings as projects, then batch all the projects together: if your pc crashes in the middle of one encoding, you only lose one encoding when batching. The files already encoded will be fine.
Need help converting to MP4 with TMPGEnc Express
By rede96 in forum Video ConversionReplies: 0Last Post: 11th Aug 2011, 15:29 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 15:06 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 14:01 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07
