Hello, I'm using Windows Vista Ultimate operating system. I have two video cards both ATI Sapphire (can enable crossfire but don't). I have setup a monitor and a projector as two seperate displays (forgot the term for this but I can have up to four split displays). I previously had a TV setup instead of this monitor and at that time my projector displayed perfectly, when I ditched the TV and went with this monitor (20" IBM) I had to end up changed all my settings and starting over. Well, now no matter how I change my settings in the ATI control center, my projector seems to be "zoomed" in. That is, the desktop picture only shows part of the image and is blurry, when I drag, let's say a movie, it used to come up the correct size - i.e. a 720p movie would just take up the whole screen... Well now, when I drag even a DVD quality movie it takes up way more than the screen of the projector. It still looks okay when I'm able to snap the movie to fullscreen, but images, and menus look like crap and are close up and blurry. When the projector starts up, it is so hard to read as compared to before, but it looks like it still says 720px60 hertz. I would think this is a stupid Windows type problem or maybe even though the projector and monitor are on seperate video cards, they can't handle the additional resolutions as the TV I was using before was just a crap old 19" analog. I can provide additional info as needed. Some help woud be GREAT, I'd rather not have to go through everything again and again. Thank you so much.
go to the catalyst control center and find the overscan/underscan settings..you'll see a slider bar that goes from 0 to 15...change that till it's pixel perfect on your projector.
Any idea what menu that would be under? Or if there is another name for it? So far, I have not seen it anywhere.
"Cropping" maybe.
720p source or downsize 1080p to 720p ?
By vcddude in forum Video ConversionReplies: 4Last Post: 19th May 2011, 18:40 -
What's the BEST way to convert HD .m2ts (720p) to a HD .mp4 file (720p)??
By elgy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Jan 2011, 19:03 -
2 x 720p AVI with DTS - need 1 x 720p MKV with AC3
By snadge in forum Video ConversionReplies: 2Last Post: 25th Oct 2009, 12:38 -
UNDERWATER VIDEO - Should I get a still-cam with 720p, or a 720p camcorder?
By v1ru5 in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2009, 02:49 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 19:23
