Im having a bit of a problem. I need to convert some FLVs i have to DV video so i can edit them in premiere elements since it seems to be the only format i can use where the audio doesnt get out of sync with the video. The problem im having is that every conversion tool ive tried automatically sets the resolution to 720x480 or 720x576, and the FLV is 640x480 so the picture comes out either too thin or too wide. Does anyone know of a way i can convert my videos to DV video in 640x480? Thanks
	I'm pretty sure that dv only supports 720x576 and 720x480.
 But doesn't premiere elements supports mjpeg or huffyuv or lagarith(if you have installed the codecs). Convert using avidemux.
	It would not be DV video if it wasn't 720 x 480 for NTSC (North American) video. Have you checked the other Premiere presets? I don't have the whittled-down Elements version, but there is a Video For Windows MJPEG format that is 640 x 480, which should work. With that said, I have done plenty of conversions from 640 x 480 to 720 x 480 and the stretch is negligible to the eye. Unless, of course you are shifting between 4:3 and 16:9 aspect ratios.
 Your biggest problem, in the end, will be the crappy quality of the highly compressed source flv file. There is no cure for that.
	Thanks i'll try the otehr formats. Im a bit of a novice, as im sure you can tell. As for the FLV source, its the only place i can get them unfortunately.
  How can I change (patch) the initial resolution of *.swf/*.flv videos?By pxstein in forum Video ConversionReplies: 1Last Post: 24th Jan 2011, 17:47
  FLVSplitter / FFDshow FLV resolution anomalyBy davexnet in forum Video ConversionReplies: 9Last Post: 16th Nov 2010, 00:22
  Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVIBy videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 01:14
  Problem with artifacts in flv conversion - i.e. converting to flv from aviBy brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 23:09
  Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 23:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
