Recently I used Seagate Disk Wizard from BratPE CD to successfully create image and restore to partition on a Win2k SP4 system. It took just 4 minutes to create image of 7GB of data, 2 minutes to validate image and 6 minutes to restore image compared to about an hour for each step using Ghost 2003.
I'm much impressed with th difference in time, but the Disk Wizard image file is invisible to Windows. The folder shows 0 bytes when properties for folder are checked, and no files are seen when the folder is opened in Windows. Is this normal, and how can such files be deleted either from Windows or from Disk Wizard? Previously using Ghost 2003 I'd create system image every 4 months and delete images over 8 months old and would like to do the same for Disk Wizard images.
