Apologies for my noobishness but bare with me
My problem: I authored a DVD with DVD Lab Pro 1.52 which has two VTS sets. each with one half of the movie in. unfortunately i (like an idiot) didnt bother checking the end link for the first VTS so instead of carrying on with the second part it goes back to the main menu.
is there a way i can just change the link without having to reauthor the DVD?
btw i dont have the project files anymore so its a fix or completely rebuilding the thing from scratch
people have mentioned IFOEdit and PGCEdit and DVD Remake Pro but i havent found a single tutorial that tells me how to change the link (if that is what its called)
can anyone help?
thanks
Results 1 to 1 of 1
How to change the Menu without affecting the structure of the originalDVD
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 20th Dec 2011, 08:34 -
how to change the Menu without messing up the whole DVD structure?
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2010, 10:12 -
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 22:41 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2009, 23:58 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 05:51
