    Apr 2009
    I am trying to convert .VOB files to .mp4 files so I can be edit them with iMovie, but so far, I have not been able to get ffmpegX to accomplish this. Whenever I try, I wind up with an empty file. Process information displays the following message:
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Sat Apr 4 10:18:45 EDT 2009
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Input #0, mpeg, from '/Users/antony1/Movies/VIDEO_TS/test.VOB':
    Duration: 00:00:55.1, start: 0.211411, bitrate: 139672 kb/s
    Stream #0.0[0x80]: Audio: ac3, 48000 Hz, stereo, 256 kb/s
    Stream #0.1[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 352x480, 4400 kb/s
    Codec type mismatch for mapping #0.0 -> #0.0
    Occasionally it says the following:
    Could not find input stream #0.2
    Any ideas?
  2. This file presents first the audio track, then the video track. FFmpeg always expects the opposite. Check the "invert track mapping" options, under the "audio" tab.
    Apr 2009
    It works now, but only half the video was converted. The original video was 90 minutes long, but only the first 49 were converted. Is there a maximum video size that ffmpegX can handle?
  4. This may be caused by an incorrect time code setting (e.g. if the present .vob file was made by assembling 2 other .vob files). MPEGStreamclip is able to fix that and can also do the .vob>.dv conversion (QuicktimeMPEG-2 component required for both operations) ; you can try Mpgtx as an alternative .
    Apr 2009
    I think I figured it out. The original was on a DVD, and ffmpegX will not read directly from that media. So, I copied the VOB file over to my hard drive, only to realize that I had left half of the video behind. MPEGStreamclip looks like it is able to do the job, without all of the hassles of ffmpegX.
    Thank you for your help.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Is the source a commercial/retail DVD? If it is, you'll have to rip it before most of the converters will be able to do anything properly with the VOBs.
    Apr 2009
    No, it was originally recorded on VHS then copied to DVD.
