I was just wondering if anyone knew how or with what software that I can re encode my MKV (~25 minutes average + .ass/.ssa/.srt subtitles) that are around 200+ mb. each down to less than 100. I have two different MKV files of the same video, one is 200 megabytes and the other one is 60, and the 60 meg has the same subtitles, and the actual size of the video screen playing is just barely smaller than the larger files screen. Trying to save space on my computer ^.^ I cant seem to find any guides on the internet which is surprising. If anyone has one, or knows of software that can help, it would be much appreciated. Here's a list of what I do use:
Converting: audialhub, Handbrake-> i use this to convert to MKV. MKVtoolnix -> mux subtitle files to MKV files.
Thats about all I can do, just looking for a way to shrink, with minimal loss in video quality. I've heard that I need to cut resolution as a start, and smooth the video out. whatever smoothing means. Its just a lot of complicated stuff that I'm new to.
You need to supply more details on the videos to be able to assess the likely damage. But I seriously doubt that you can reduce the size by 50% without a noticeable drop in quality unless the original is using a stupidly high bitrate, or already has a very low resolution.
Personally, I would go and buy a cheap external HDD and use that for storage. Far better solution than crushing perfectly good video.
However if you are not convinced, start by posting detailed specs of the 200 and 60 MB files.Read my blog here.
Alternative to HuffYUV for VHS capture.. Need smaller file sizes
By HDClown in forum Capturing and VCRReplies: 19Last Post: 16th Sep 2011, 15:48 -
How can I compress my captured videos to smaller file sizes?
By matta2k in forum Video ConversionReplies: 5Last Post: 6th Apr 2011, 08:31 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 14:11 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 02:53 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 07:07
