Hello,
I have a whole bunch of VOB files in 4:3 format (over 1000!) that I need to convert to 16:9 - I know how to do this now (thanks to this forum) using DVD Patcher. But this utility is a one-at-a-time deal. What I would really love is something that would allow me to batch process these files.
So, is there a way of running DVDPatcher in batch mode, maybe via a DOS batch file perhaps using command line parameters? Or is there another utility which would do this for me?
If there is nothing for VOB files I could use something like Streamclip to batch convert all the VOBs to MPGs first and then maybe use another utility to batch process the Aspect Ratio of the MPG files?
Any help gratefully accepted.
Regards,
Lt. Dang
The only way that I have been able to successfully do this was with VideoRedo. When saving, you can go into the options screen and set the defaults for video output. One of the options is the aspect ratio. If you set the aspect ratio to 16:9, you can batch convert the files (and run QuickStream Fix).
Jason -
Thanks for the suggestion - I will give it a try.
Regards,
Lt. Dang -
Yes indeed. Can you, or anybody, confirm whether this procedure is indeed lossless (no re-encoding) just like the cuts? I would assume so due to the speed at which it's done - a quick change of the PAR flag and that's it. But still not 100% sure on this. (And I don't get the Bit Rate changing either...)Originally Posted by txporterI hate VHS. I always did.
vob to wmv crop/aspect ratio???
By eao1 in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2009, 15:00 -
VOB Aspect Ratio
By Lt. Dang in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 19:17 -
How can I edit *.bdmv files to correct aspect ratio?
By smnckl in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 11:50 -
ifo edit / Need help in editing DVD transport function & aspect ratio
By chazuke in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2008, 08:58 -
.vob to .dv, aspect ratio problems
By Groove_Holmes in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2008, 21:34
