Results 1 to 10 of 10
    Apr 2009
    Canada
    Hi guys I used to have a piece of software way back that did this but I lost it when my pc crashed so I was searching for it or a new one and it lead me here were other were asking similar things hope you guys can help
    the program I am looking for has to be able to take screenshots automatically every say 2 seconds
    the one I had did this I set it to take shots every few seconds and left it and that was it I would have a folder full of shots
    anyone have any ideas
    Nov 2003
    Everywhere I want to be
    Irfanview
    Capture areas: All monitors, current monitor, current window, current window's client area
    Capture Method: Automatic every X seconds
    Saving Method: Filename template, location, and file type all set-able.
    Apr 2009
    Canada
    I know this might make me sound stupid but I am not up on all this that will work with any media program ie windows media player and windows media player classic
    Apr 2009
    Canada
    ok I tried this program and nothing it does not work with video it just shuts down
  5. imagegrabber 2 is another option
    you can also use vdub and set it for the frame range by using avisynth script as input (.e.g selectevery() )
    Jun 2006
    Canada
    I don't think that's possible. Many players use overlay which is impossible to capture with a standard screen capture. Some players can work with the overlay mode switched off.
    FYI in overlay mode, the application window (where the video is) is actually black. The video shows through anywhere the screen is black. The application places the video "behind" the black window and it's visible. If you try to capture, you will get plain black. In such a case you have to use the capture utility that comes with the application.
    My ATi TV uses overlay. If I place a jpg over the top, the video is blotted out everywhere except in places the jpg is black.
    Apr 2009
    Canada
    image grabber 2 seems to do the job but not worked out how to use the settings as yet and where it saves the pics
    Feb 2004
    Australia
    Vlc + auto it script (shift + s) with event timing ... simple
    Apr 2009
    Canada
    thanks guys I found the old program I was using again
    FreeVideoToJPGConverter
