I have a copy of FastEmpire Monsters Inc which in bin and cue files. I can't seem to be able to convert this to an mpeg. I upgraded to the latest version. I get a message;
"Could not locate MPEG stream"
I tried checking;
fix mpeg errors
remove cd-i mpeg bumper
include track 0
And it still will not work. I was able to make a VCD with the files, using fireburner. Thanks for any help.
I don't see why you were trying to use VCDGear if burning the Cue/Bin files worked as is, you can always try using ISOBuster to extract the DAT from the Bin.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Thanks Sefy, I understand your confusion. I want to extract the actual mpeg2 as a single file. Thanks, I'll try your suggestion.
Well because Monsters Inc is SVCD and you trying to convert it to VCD with VCDgear, this will only distort the picture if you did get it to burn. Like Sefy said the best way is to extract the MPG from the bin using IsoBuster.
I have tried what have done ....it works like i said but it is distorted.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 11:25 -
New MKV File-convertxtodvd won't convert it.
By jbitakis in forum Video ConversionReplies: 17Last Post: 4th Feb 2009, 15:51 -
RMVB file won't convert?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 20:34
