i have been having a problem making a backup copy of dark knight and the new movie twilight can anyone help maybe i am doing something wrong never had the problem backing up before please HELP thanks
Looking into my crystal ball . . . . . . . . . . . . . . . .
Nope. Can't see what you are doing wrong. Probably because you have supplied nothing of use.
What programs have you tried ?
What methods ?
Are you using the latest versions of the software ?
Have you read any guides or bothered to read through any other posts ?
Isn't it a bit late for Release Tuesday ?Read my blog here.
Huh...
I just backed up my son's Twilight last night with no problems what so ever 8) -
You don't provide much useful information. :P
Assuming the problem discs have one of the newer protections, rip first with the latest DVDFabHDDecrypter (free), then run FixVTS (free) on the ripped files to correct the structure. (FixVTS is only occasionally necessary, but it takes very little time). You should then be able to open the ripped files with DVDShrink, DVDRB, or whatever you normally use.
Good luck and welcome to the forum.Pull! Bang! Darn! -
What programs you can do it with haven't changed for years. Try what fritzi93 says.
Yep, i used the latest version of DVDFabHDDecrypter to rip and dvdshrink to shrink it.
Silly me, i guess if i actually posted some helpful information it would have been more useful
One post wonder strikes again
Back up 1 title track split across 2 DL DVDs
By soneman in forum DVD RippingReplies: 11Last Post: 24th Mar 2010, 05:50 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
Back-up 2 SL dvds to 1 dvd+r dl?
By bgart13 in forum Authoring (DVD)Replies: 8Last Post: 22nd Apr 2008, 22:44 -
Erros at and of DVDs when played back
By ronknights in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2008, 11:18 -
What would you recommend for an older person to back up DVDs
By billolmesdahl in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2007, 19:27
