    Apr 2009
    i am trying to rip a dvd on mac the ripper and put it in .mov format or something so that i can reead it with my final cut and edit it.
    but the format is all wrong. any suggestions?
    Apr 2004
    Miskatonic U
    Damn. My crystal ball is working over time, and failing miserably.
    Would you care to add some details ?
    What did it produce ?
    DVDs are Mpeg-2 (generally, although mpeg-1 is permissible) in the VOB container. If MTR only rips, you still have VOBs. Because you are working on a Mac, you probably have to re-encode the video to another format so FCP can open it, in which case you probably need to use something like Handbrake.
    Read my blog here.
  3. Member Mr anderson's Avatar
    Jan 2004
    Moving you to our MAC section.
