I am not computer illiterate but am certainly not savvy on the video/audio side of things.
I have been using FAVC which suits my requirements perfectly only, it is pot luck whether it generates a full DVD or encode or not. FAVC (tried both 1.06 & 1.07) has with HCenc has been good to me. But had enough of crossing my fingers in hope it'll work, wasting time.
I have had a look around and taken a peek at HCbatchGUI but it all goes straight over my head.
So out of desperation I am asking what alternative method(s) to generating a full DVD at best quality encode out there?
I don't mind learning at all but since I convert .mkvs and .avis on a weekly basis it would be a bonus if isn't more hassle to achieve than it is worth.
Results 1 to 10 of 10
FAVC is typically reliable, however you could also give ConvertXtoDVD or DVD Flick a try.
Google is your Friend -
the film machine works fairly well.
but nothing is going to make a quality dvd out of poor source material. what or where are you getting the mkv and avi files from? -
Originally Posted by Krispy Kritter
Some are very partisan in favor of AVStoDVD, with its two-pass approach. My first experiment with that did not go so well, but it is more complicated than ConvertX. I look forward to trying it out again, in a later version, once I have the better computing horsepower to do it justice.
Avanti is another one in this general category.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
@Minidv2dvd
No s**t.
Thanks for the suggestions, heard of them all but I will check them all out.
The .avis are typically
Video: 1 000 Kbps , 624 x 352
Audio: 128 Kbps, 2-channels,MP3. Or higher
The .mkv are are typically
Video: 3 000 Kbps, 1280 x 720
Audio: 384 Kbps, 6-channels, AC-3. Or higher
So, what my first post/title should have said is what app is best for retaining as much quality as possible.(title now changed) (Yea, it's technically the encoder not the app of course.)
FAVC results using HCenc set to "Quality" retains and produces excellent quality. Which is why I have been using it. Quality is at the top of the list for me.
Tried using FAVC 1.06 twice today with a .mkv but the video & audio was 2x as fast and not understandable sounding.
mkv file info:
Code:General Complete name : ******** Format : Matroska File size : 1.09 GiB Duration : 41mn 46s Overall bit rate : 3 746 Kbps Encoded date : UTC 2009-04-02 02:51:05 Writing application : mkvmerge v2.3.0 ('Freak U') built on Oct 7 2008 20:39:59 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 41mn 43s Bit rate : 3 205 Kbps Nominal bit rate : 3 359 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.145 Writing library : x264 core 67 r1123tw Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40 / rc=2pass / bitrate=3359 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Language : English Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 41mn 46s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz
There was mention of lowering the video Bierate to 7000 due Muxman can be possibly being sensitive to spikes. Didn't resolve anything anyway.
FAVC 1.07 supposedly has problems retaining AC3 audio. -
So I tried the following:
AVStoDVD
Didn't work. Can't remember why. Possibly didn't like the HQ matroska?
DVD Flick
Minor jumps in video every several seconds. | Quality OK, not what I am used to with FAVC/HCenc but satisfactory I guess.
ConvertXtoDVD
No video problems | Quality OK, again, not what I am used to with FAVC/HCenc but satisfactory I guess. Pretty fast for "High quality encoding".
I will have to take snapsshots to compare next time. Bit hard to judge from memory. I wasn't thinking. Just a tad fed up with all this converting.
If you were going to produce the best possible HQ DVD you could what would you do? -
I have been using AVStoDVD, and only had one video that it refused to encode. Usually when this happens with FAVC (which balks at MKVs more often than AVStoDVD), unpacking the MKV with MKVExtractGUI, then creating a new MKV with just the audio and video tracks I need fixes the problem.
The cost of the convenience with ConvertXtoDVD is that the quality, while not bad, is not as good as AVStoDVD/FAVC. The next version of ConvertX will offer 2 pass encoding, although we will have to wait to see what difference, if any, this actually makes.
If I had a quality source, I would write my own avs script, encode with HCEnc doing a two pass encode, then author with DVD Lab Pro.
Otherwise I would learn how to get the best out of AVStoDVD, and also how to rebuild MKV files, which are notoriously unreliable for conversion because of the amount of crap you can store in that container format.Read my blog here.
I installed a recent version of ffdshow then removed it. It took along with it a mpeg codec of mine...
How to create DVD that retains CC on source file
By Stiff Neck Man in forum Authoring (DVD)Replies: 0Last Post: 13th Jan 2012, 10:12 -
Low File Size yet retains the original quality. How?
By NeroLi8gerzid in forum Video ConversionReplies: 8Last Post: 6th Oct 2011, 17:46 -
Convert to DVD (VOB) Highest Quality converter?
By Mark97213 in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2011, 10:47 -
Best video converter for QUALITY
By madmartian in forum Video ConversionReplies: 45Last Post: 20th Mar 2010, 15:45 -
Any Authoring program that RETAINS the Copy_Once bit ?
By mbextreme in forum Authoring (DVD)Replies: 6Last Post: 18th Jan 2008, 11:34
