In that case, it seems the correct solution is to do no framerate converting with DVD Flick or DVD player. Just let the TV do the "converting".As I understand it, most PAL TVs will switch to 60 Hz scanning when playing NTSC
Results 31 to 32 of 32
But, as noted, you will have 3:2 judder on top of the normal jerkiness of 24 fps film. 25 fps viewed at 50 fields per second will be slightly smoother because you'll only have the inherent jerkiness of 25 fps.Originally Posted by jimdagys
The inherent jerkiness of 24 or 25 fps won't be very noticeable on the test clip you posted, the motions are too small. Find a bright, high contrast, medium speed, panning shot. It will appear jerky or flickery. This is easily seen on TV or in the movie theater.
Digital Camera question
By wingfan in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2010, 15:27 -
Panasonic AG-HMC150P... Jumpy pans?
By Try4ce in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 17th Mar 2010, 18:27 -
slow pans are jerky on DVD after Premiere Pro exports
By spicediver10191 in forum Authoring (DVD)Replies: 15Last Post: 6th Nov 2007, 21:59 -
Digital Camera Question
By tenders in forum Off topicReplies: 57Last Post: 25th Jun 2007, 16:52 -
How to remove stutter in pans ???
By stars in forum Video ConversionReplies: 1Last Post: 11th May 2007, 10:03
