That's a codec problem right? Or is it a problem with the .avi file itself?
If it's a Codec problem, does anyone else know what I might need to fix it? I've got the DivX 4.0 codecs, the Tsunami Codec Pack, and the SMR patch. Is there another one I need?
Results 1 to 9 of 9
When do you see this message? Normally this will popup while capturing from a non working FW 1394 device!
Look at DirectX Info, you should see anything you got there. -
If this is a regualr avi file, please open it with the VirtualDub Hex editor and look for the FourCC code to identify the Codec.
The goto to your registry with regedit and serach for this code under:
\Local_Machine\software\microsoft\windows nt\currentversion\drivers32
with vidc.<FourCC>
if you don't see an approbiate entry, try download the codec. It can be found with google.
BTW: what is the FourCC of your avi? -
Unless that baby takes a REAL long time to load, the hex is blank. But yet, the .avi is 124mb. Is it just corrupted?
For reference, the vidc's in my registry under that key are DIV3, DIV4, DIVX, MP42, MP43.
Any others you recommend (or places in the registry I need to look?) -
If it's completly blank, the files seems to be corrupted.AFAIK know .avi have a certain RIFF structure, but some are not RIFF and can only be played by certain players (try Mediaplayer 7.5/Quicktime/Realplayer etc).
As long as you don't need a codec, I wouldn't install it.I doing this just in time. -
Yea, just tried playing it on GDIVX and The Playa, and nothing. It's got to be screwed up.
OK, I'll just have to find another one.
Thanks!
please help me with image grabber II (class not registered) error
By bull21 in forum Software PlayingReplies: 6Last Post: 31st May 2014, 09:42 -
ImageGrebber II Class Not Registered Error
By DJboutit in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2010, 09:51 -
Class 4 and Class 6 SDHC cards with Canon HF200
By eteune in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 25th Dec 2009, 14:10 -
SD Card Class 2 vs Class 6
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Jul 2009, 15:59 -
DVD Xpress DX2 "Class not registered" error
By more_cowbell in forum CapturingReplies: 0Last Post: 30th May 2009, 18:05
