    May 2007
    My friend has files that he claims are AVCHD but they cannot be loaded by an app called Voltaic HD, which handles these types of files. GSpot utility shows they are in MOV quicktime container, but the codec field shows 'apcn' with unknown name and status. Any ideas what this video file is and how I can convert it? They play fine with MPC and cccp codec pack.
  2. apcn is a type of audio. What does mediainfo say about your file (the video stream)?
    If I were to guess, it's likely h.264 video from a camera (not camcorder), but not avchd which is probably why voltaic is disagreeing
    If it plays ok in mpc, xvid4psp should be able to convert it to most file types, another option is avidemux; but you didn't state what your goal is
    May 2007
    MediaInfo says:
    General
    Complete name : I:\Clip #53.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 207 MiB
    Duration : 11s 936ms
    Overall bit rate : 146 Mbps
    Encoded date : UTC 2009-03-16 01:05:56
    Tagged date : UTC 2009-03-16 01:05:56
    Writing library : Apple QuickTime
    Original source medium : 2009
    Video
    Format : apcn
    Codec ID : apcn
    Duration : 11s 911ms
    Bit rate mode : Variable
    Bit rate : 144 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16/9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Bits/(Pixel*Frame) : 2.322
    Stream size : 205 MiB (99%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 2.19 MiB (1%)
    I can't quite make sense of this. I'd simply like to convert these files to a more common format.
  4. Did you try the suggestions? They can output most formats
    May 2007
    Thanks for your feedback. It turns out SUPER can handle it. I'm not sure why I didn't try it first.
