I have used Dr. Divx OSS 2.0.1 (beta 7) to convert many files to "divx certified" "home theater profile" AVIs. It will accept MKVs with x264 video, whereas Divx's own Divx Converter will not. However I have three files which will cause Dr. Divx to crash immediately if I try to convert them using Dr. Divx. The MediaInfo details on the files are at the end of this email.
Q. Can anyone see something in the file details below which explains why these particular files are toxic to Dr. Divx?
Q. Can anyone recommend a different tool to convert to an AVI containing Divx which will play on an Divx Ultra Certified player (in this case, a Philips DVP-5982).
General
Complete name : C:\Medici.Makers.of.Modern.Art.mkv
Format : Matroska
File size : 2.14 GiB
Duration : 58mn 25s
Overall bit rate : 5 249 Kbps
Encoded date : UTC 2008-12-20 06:54:47
Writing application : mkvmerge v2.4.1 ('Use Me') built on Dec 5 2008 18:30:05
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 58mn 25s
Bit rate : 4 647 Kbps
Nominal bit rate : 4 936 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.202
Title : x624 r1057 skystrife at 4936 kbps
Writing library : x264 core 65 r1057M 5f8a149
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4936 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=4936 / vbv_bufsize=99999 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.50
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 58mn 25s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Title : Dolby ac3 5.1 at 384 kbps
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
General
Complete name : C:\American.Future.A.History.3of4.mkv
Format : Matroska
File size : 2.16 GiB
Duration : 59mn 3s
Overall bit rate : 5 236 Kbps
Encoded date : UTC 2008-12-04 16:35:08
Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
Video
Format : AVC
Duration : 59mn 3s
Bit rate : 4 636 Kbps
Nominal bit rate : 4 849 Kbps
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.201
Title : x264 1046 skystrife at 4849 kbps 25 fps
Writing library : x264 core 65 r1040M 1591275
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4849 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.50
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 59mn 3s
Bit rate : 384 Kbps
Title : ac3 at 384 kbps 6 ch
Language : English
General
Complete name : C:\The.American.Future.A.History.4of4.mkv
Format : Matroska
Duration : 58mn 48s
Overall bit rate : 5 268 Kbps
Encoded date : UTC 2008-12-05 22:48:11
Video
Format : AVC
Duration : 58mn 48s
Bit rate : 4 667 Kbps
Nominal bit rate : 4 881 Kbps
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.203
Title : x264 r1046 at 4881 kbps
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4881 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.50
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 58mn 48s
Bit rate : 384 Kbps
Title : AC3 at 384 kbps 6 ch
Language : English
crashes
By idolgolf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2010, 06:43 -
What to do when your PC crashes?
By aelfheah in forum ComputerReplies: 6Last Post: 29th Oct 2008, 12:27 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 20:47 -
Virtualdub crashes
By Kevlin in forum EditingReplies: 2Last Post: 18th Jan 2008, 23:01 -
2.5 crashes
By boggle in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 20th Jul 2007, 04:49
