Morning all, I am, a complete newbie to this so please bear with me if my jargon is a little dated.
Problem - I have connected my PC, a Dell 5150 with a Geforce 6600GT to my TV using a DVI to HDMI cable along with two audio cables. The screen on the TV (a 32" flat screen) has now acquired a strange green colour that I cannot remove from the PC side. The green only occurs when the HDMI channel is selected. It is not always green, just when the PC image appears, which it does, but all greenish. I would like to ask if anyone knows how to remove this problem, it is f*****g irritating and I can't watch any of the films I have on my PC.
thanks
Tim
Results 1 to 19 of 19
You must be an apprentice saint with that closing comment ...
Is it a completely green screen with no other image or text? Or is everything just a shade of green? Maybe just green and yellow?
Make sure your video card is set to something the HDMI port can handle. I'd start with 1280x720 60Hz. Check your manual for acceptable settings.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Everything is OK with just a shade of green overlayed over the image. The screen is set to 1024*768 at 60 Hz.
My saintly status is still pending with the big man!
Tim -
What make/model is the TV? Though an HDTV standard like 1280x720 should work you should use the native resolution for the TV. And, make sure you have it set to pixel mode or whatever the equivalent is for your set.Originally Posted by timmythesaint
Wouldn't lying about sainthood automatically disqualfy you?Originally Posted by timmythesaint
Have a good one,
neomaine
Don't count on anything other than standard HDTV resolutions and frame rates to work via HDMI. Once you have verified that everything is working properly you can try other resolutions.
What would the cable type have anything to do with it? Or, are you referring to the HDMI port on the TV?Originally Posted by jagaboHave a good one,
neomaine
Many HDTVs will only accept standard resolutions and refresh rates via HDMI. They typically accept a wider range of resolutions and refresh rates via VGA.Originally Posted by neomaine
The PC is DVI output from the GeForce card and the TV is a HDMI input so I got the DVI output to HDMI input cable. Unfortunately the minimum graphic card screen speed is 60 Hz. Any suggestions?
Tim (status still pending). -
It's not really a matter of HDMI abilities, it's the ability of the TVs. But I believe HD PAL has retained the same 50 Hz legacy from SD PAL. For example, you see 50/100 Hz advertised for the new HDTVs in Europe, whereas you see 60/120 Hz in the USA.
I finally bit the bullet yersterday and ordered a DVI to VGA cable. That should arrive tomorrow (Friday) and we can give that a whirl. I am a bit annoyed that the HDMI cable doesnt work properly. All my pissing about with the PC has caused a lot of swearing and throwing of things. My 3 year old son has really had a lesson in how not to behave!
Let's see how things work in VGA country.
Thanks for all your input so far,
Tim -
Did you try a different DVI/HDMI cable? Different HDMI inputs on the TV or another TV? Different DVI output on the computer? These are all obvious troubleshooting steps.
Hello all,
well the plot thickens. Now I have a perfect image from the PC to the TV (my DVI - VGA cabel arrived) but now I have no audio, through the TV. What the hell am I doing wrong?
I have a SigmaTel Audio card in the machine and appear to have connected the cables (1 out from the PC to two into the TV) but not even a twitter. I am getting a little frustrated with my latest project. Any words of wisdom. You have all helped a great deal and for that I thank you.
Tim -
Some cards have connections that can be configured as inputs or outputs via the setup applet. Make sure yours is configured correctly.
If you have more than one output you may have to configure your speaker setup too. -
Hello all,
I have now connected the audio cables through the hedaphone socket on the PC - AND IT ALL WORKS! Nice. Thanks for all your input. It was truly appreciated.
Tim -
For the TV HDMI input, you MUST read the manual to see if PC connection is supported and at which frame rates and resolutions. Many PC display chips fail to provide a true 1920x1080i/25fps or 1280x720p/50fps over DVI-D. You may have better luck feeding 1080i/25 over analog component.
HDTV sets with VGA (PC/Game port) are more forgiving on frame rate (60Hz typ) and offer a selection of VESA type resolutions. VGA out is always progressive. Deinterlace happens in the display card. Feed the TV at display native resolution for the sharpest picture.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Avidemux Green Screen
By FrozenInferno in forum Video ConversionReplies: 4Last Post: 2nd Apr 2011, 23:31 -
Green Screen Advice
By HoosierGuy in forum Newbie / General discussionsReplies: 19Last Post: 8th Mar 2011, 09:53 -
TMPGEnc green screen
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 17:06 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 20:35 -
I dropped my ipod and its made screen go all funny.
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 30th Aug 2007, 11:12
