I have been working all day on this, I've tried converting mp4-DVD, AVI-DVD, and MOV-DVD but when it encodes it the file it give me is something like video.mov.ff.m2v rather than something like video_TS with the correct files inside.
Also, in the tools -> author tab I have selected: Author as: DVD Video_TS.
If anyone can help me make the video_TS files woud be greatly appreaciated.
A .m2v extension is for the video stream. Apparently, ffmpegx never made it to converting the audio stream, which is why the program terminates without creating a VIDEO_TS folder. Either the video stream has a problem that made ffmpegx choke, or the audio is in a format that ffmpegx doesn't support. If the .m2v has all of the video expected (you can view it with, say, VLC), then the problem is likely the latter.
What does ffmpegx say about the source audio stream (in the summary window)? Better yet, post the contents of the logfile (click on the blue "i" in the Progress window when you are attempting to convert). Much useful information is to be found there.
The file wouldn't load in quicktime but I'm not sure about VLC. I don't currently have that file or the log anymore but I'm reencoding it now so I'll reply with the log if it doesn't work.
fmpegX can't find Progress.app
By fincat in forum ffmpegX general discussionReplies: 1Last Post: 22nd Jan 2011, 22:22 -
problems making dvd from vob files only
By Dr_Sanguinary in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 07:20 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 15:43 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18
