Smart ripper ver 2.31 rips at 1X all the time.
Takes about 1- 1 1/2 hours to rip.
Other machines with my spec are doing it in 15 min.
1) 16X DVD-ROM
2) 1.2GHz Athlon + 512MB memory
3) 40 GIG UDMA-100 hard drive
4) Windows ME
Proberly a bad configuration-setting, or bug in prog.
I've got nearly same configuration with you, only I got 256SDRAM. With me it runs fast (complete movie in just a few minutes : not 15min.)
Try another version of SmartRipper. Keep in mind that SmartRipper only runs on an ASPI-driver. wNT4 doesn't have one installed if your mb is same like me : VIAchipset. If you've w98se or wME it souldn't be a prob, didn't test yet with w2k. -
Ah! Had the same problem
Not sure if it will work for you but this is how I got round the problem.
My DVD reader was set to slaved to the H/D, All I did was moved it to master on it's own ide channel & hey presto, The matrix ripped in 10:01 mins. I asume you've got the h/d on the udma channel ?
Av read speed was 6x - hope to get this upto 10+......if anyone has any suggestions.
Rip In Peace
I had slow ripping problems until I flashed my bios and then it sped up. I have a abit kt7 raid, if you have an abit I suggest flashing your bios.
<font size=-1>[ This Message was edited by: Shifthrow on 2001-07-24 16:03:07 ]</font> -
This topic made me excited
, i just bought a P4 system and wanna give it a try,so i enter the BIOS and set the drive that handle my DVD drive to AUTO,saved changes and reboot . Put a DVD ( 7.2 G) in and ripped, i try to rip 5G
and cal the minutes : wow it's really suprised me :8 minutes
( i used with newest Smart ripper )
DVD speeds from 5.5X - 10.8X .
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
