Changing subtitle colours in DVDSubEdit does not 'take' unless the IFO values are reset using IfoEdit.
The pics show how the same subtitles are assigned values in DVDSubEdit and IfoEdit respectively.
If I change the e2, e1,p,b values in DVDSubEdit, how can I translate the new values, so that I can enter them in IfoEdit?
It's much easier and more accurate to change them using PGCEdit. Open the DVD, double-click on the movie and then change them in the CLUT (Color LookUp Table), the 4x4 block of colors you'll see. The colors you want to change are often (but not always) found in the top row. After saving, test it out in a software player before burning to disc.
However, I've had no trouble changing them using DVDSubEdit either. After changing one are you going Edit->Apply Last Modifications To All before then saving the changes? As near as I can tell, that DVDSubEdit pic isn't showing any colors. It's only showing transparency values. The 2 pics show 2 different things. -
Thank you - I think I was messing up the save part of the procedure.
I have made the changes and they now 'stick' on playback.
Subpicture highlights look jagged on TV
By Henkie in forum Authoring (DVD)Replies: 9Last Post: 10th Feb 2014, 13:08 -
How can I replace one subpicture with another?
By doctorjellybean in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2009, 07:59 -
simultaneous display of 2 subpicture streams?
By Radish in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2009, 02:31 -
How to remove subpicture from DVD
By Scenik in forum DVD RippingReplies: 3Last Post: 9th Mar 2008, 15:14 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
