Hi all.
I've always burn my DVDs (movie and data) with no problems. Even with crappy brands I get no error.
The writer is an internal one in my ACER laptop. Max speed is only 8x.
Recently I can't burn any DVDs. For DVD movies, I've always used their DVD-Video template.
Here's an error message from NERO:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 9.2.5.100
Internal Version: 9, 2, 5, 100
Recorder: <PIONEER DVD-RW DVRKD08RS>Version: 1.02 - HA 1 TA 0 - 9.2.5.100
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVRKD08RS>Version: 1.02 - HA 1 TA 0 - 9.2.5.100
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVRKD08RS atapi Port 0 ID 0 DMA: Off
DiskPeripheral : WDC WD2500BEVS-22UST0 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVRKD08RS E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2038MB (2087276kB)
Free physical memory: 778MB (797144kB)
Memory in use : 61 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.3.2009
UDF/ISO compilation
6:54:44 AM #1 Text 0 File SCSIPTICommands.cpp, Line 452
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:54:44 AM #2 Phase 112 File dlgbrnst.cpp, Line 1767
DVD-Video files reallocation started
6:54:44 AM #3 Phase 114 File dlgbrnst.cpp, Line 1767
DVD-Video files reallocation completed (no file modified)
6:54:44 AM #4 Text 0 File Isodoc.cpp, Line 6940
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
6:54:44 AM #5 Phase 111 File dlgbrnst.cpp, Line 1767
DVD-Video files sorted
6:54:44 AM #6 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
6:54:44 AM #7 ISO9660GEN -11 File Geniso.cpp, Line 3349
6:54:44 AM #8 Text 0 File Burncd.cpp, Line 3587
Turn on Disc-At-Once, using DVD media
6:54:44 AM #9 ISO9660GEN -11 File Geniso.cpp, Line 3349
6:54:44 AM #10 ISO9660GEN -11 File Geniso.cpp, Line 3349
6:54:45 AM #11 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 2298495
Last address to be written: 2153855
6:54:45 AM #12 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
6:54:45 AM #13 Text 0 File DlgWaitCD.cpp, Line 2882
Recorder: PIONEER DVD-RW DVRKD08RS, Media type: DVD-R
Disc Manufacturer ID:
Disc Application Code: 64, Disc Physical Code: 193
6:54:45 AM #14 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
6:54:45 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 744
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2153856 (2153856) = #2153856/478:38.6
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2153856 blocks [E: PIONEER DVD-RW DVRKD08RS]
6:54:45 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 946
Prepare [E: PIONEER DVD-RW DVRKD08RS] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4411097088, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2153856 | 0 | 0x00
2153856 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
6:54:45 AM #17 Text 0 File SCSIPTICommands.cpp, Line 242
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
6:54:45 AM #18 Text 0 File Burncd.cpp, Line 4320
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
6:54:45 AM #19 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
6:54:45 AM #20 Text 0 File Burncd.cpp, Line 4442
Cache writing successful.
6:54:45 AM #21 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
6:54:45 AM #22 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11,080 KB/s)
6:54:45 AM #23 Text 0 File ThreadedTransferInterface.cpp, Line 2676
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:54:45 AM #24 Text 0 File DVDR.cpp, Line 3279
Recording mode: Sequential Recording Mode
6:54:45 AM #25 Text 0 File DVDR.cpp, Line 3433
Start write address at LBA 0
DVD high compatibility mode: Yes
6:54:45 AM #26 SPTI -1066 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x0805a400: Len x648
6:54:45 AM #27 Text 0 File Cdrdrv.cpp, Line 9966
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Transfer Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: -
Revision number of minimum recording speed: -
Revision number table of recording speed: - - - - - - -
Class: 0, Extended part version: 0
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
6:54:45 AM #28 Text 0 File DVDR.cpp, Line 3571
Reserved Track size: 2153856 (20DD80h, 4206MB) -> return code 0
6:54:45 AM #29 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
6:54:46 AM #30 Text 0 File Cdrdrv.cpp, Line 1274
06:54:46.406 - E: PIONEER DVD-RW DVRKD08RS : Queue again later
6:55:47 AM #31 Text 0 File Cdrdrv.cpp, Line 1274
06:55:47.593 - E: PIONEER DVD-RW DVRKD08RS : Queue again later
6:55:58 AM #32 SPTI -1064 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
CDB Data: 0x2A 00 00 00 03 E0 00 00 20 00 00 00
Sense Code: 0x21
Sense Qual: 0x02
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 21 02
Buffer x09d40800: Len x10000
0x00 00 01 BA 44 03 24 32 4C 57 01 89 C3 F8 00 00
0x01 BD 07 EC 81 80 05 21 00 C9 4F 3B 80 03 00 04
0x00 FC 28 0B 77 E5 FB 14 40 4B 7F E3 07 FC F3 62
6:55:58 AM #33 CDR -1064 File Writer.cpp, Line 306
Invalid block address
6:55:58 AM #34 Text 0 File DVDR.cpp, Line 3838
EndDAO: Last written address was 991 (3DFh)
6:55:58 AM #35 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
6:55:58 AM #36 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11,080 KB/s)
6:55:58 AM #37 Text 0 File SCSIPTICommands.cpp, Line 289
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
6:56:01 AM #38 Text 0 File Cdrdrv.cpp, Line 11243
DriveLocker: UnLockVolume completed
6:56:01 AM #39 Text 0 File SCSIPTICommands.cpp, Line 452
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
So what's suddenly screwing with my DVD burning now?
Results 1 to 10 of 10
I would first try a different media. If you are already using a quality media (Verbatim or Taio Yuden), then it's also possible your drive has simply failed. Notebook drives don't have near the lifespan of a standard PC drive.
Google is your Friend -
I saw three problems in your log.
The first was:
That tells me the drive is operating in PIO mode. Very slow and very CPU intensive. Try this:
The next error may be related to the first:To check DMA/PIO mode within Windows:
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer.
That's usually a communication error from the software/hard drive to the burner.CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
The last was:
The disc is unidentified.Disc Manufacturer ID:
For that, I would try another brand of disc, as Krispy Kritter mentioned.
And if you are just burning DVD discs, I wouldn't use Nero. ImgBurn works much better and is free. I don't have Nero on any of my systems anymore. -
Hi redwudz.
My OS is Windows XP 5.1 SP2.
Under the Disk Drive>Properties (in Device Mgr), I can't see an Advance Settings.
I see 5 tabs: General, Policies, Volumes, Driver, Details.
The Same with my DVDWriter drive, I can't see an Advance Settings.
I see 6 tabs: General, Policies, Volumes, Driver, Details, Region.
I can't see any DMA / PIO related settings.
I do want to burn Data DVDs too e.g. MP3 / video collection.
Currently I can play DVD movies & Data DVDs (those I previously burnt when all was OK) perfectly.
I even tried enabling "Simulation" in Nero with and without the Burning but in both cases Simulation just failed. I get a "Invalid Block Address" message in the status window.
I noticed that when trying to burn in Nero, the Burn tab got "Verify written data" disabled so I can't tick it.
I tried Nero DriveSpeed but I get a "No CD-ROM found" message.
I bought this laptop around Dec 2008. I can't take my laptop back to the shop I bought it for repair/check up because it's in a different town & far from me.
IS there a way I can check if my writer/the laser thingy in it is physically ok? Maybe with another software.
Device Mgr says "This device is working properly". I want another opinion.
This is the log message when I tried to burn a data DVD :
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 1526MB (1563360kB)
Memory in use : 25 %
11.4.2009
ISO compilation
1:21:17 PM #1 Text 0 File SCSIPTICommands.cpp, Line 452
1:21:17 PM #2 Text 0 File Isodoc.cpp, Line 6940
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
Joliet : TRUE
1:21:18 PM #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
1:21:18 PM #4 Text 0 File Burncd.cpp, Line 3587
1:21:18 PM #5 Text 0 File DlgWaitCD.cpp, Line 313
Last address to be written: 2188655
1:21:18 PM #6 Text 0 File DlgWaitCD.cpp, Line 325
1:21:18 PM #7 Text 0 File DlgWaitCD.cpp, Line 2882
Disc Manufacturer ID: <DAXON0> <16S>
1:21:18 PM #8 Text 0 File DlgWaitCD.cpp, Line 500
1:21:18 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 744
original disc pos #0 + 2188656 (2188656) = #2188656/486:22.6
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2188656 blocks [E: PIONEER DVD-RW DVRKD08RS]
1:21:18 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 946
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4482367488, ISRC ""
DAO layout:
0 | 1 | 1 | 0x41 | 2188656 | 0 | 0x00
2188656 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
1:21:18 PM #11 Text 0 File SCSIPTICommands.cpp, Line 242
1:21:18 PM #12 Text 0 File Burncd.cpp, Line 4320
1:21:18 PM #13 Phase 24 File dlgbrnst.cpp, Line 1767
1:21:18 PM #14 Text 0 File Burncd.cpp, Line 4442
1:21:18 PM #15 Phase 25 File dlgbrnst.cpp, Line 1767
1:21:18 PM #16 Phase 36 File dlgbrnst.cpp, Line 1767
1:21:18 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2676
1:21:18 PM #18 Text 0 File DVDR.cpp, Line 3279
Recording mode: Sequential Recording Mode for Multisession
1:21:18 PM #19 Text 0 File DVDR.cpp, Line 3433
1:21:18 PM #20 SPTI -1066 File SCSIPassThrough.cpp, Line 215
Sense Code: 0x24
Sense Qual: 0x00
Buffer x04b45140: Len x648
1:21:18 PM #21 Text 0 File Cdrdrv.cpp, Line 9966
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Revision number of maximum recording speed: 6.0
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
1:21:18 PM #22 Text 0 File DVDR.cpp, Line 3571
Reserved Track size: 2188656 (216570h, 4274MB) -> return code 0
1:21:18 PM #23 Text 0 File ThreadedTransfer.cpp, Line 273
1:21:20 PM #24 Text 0 File Cdrdrv.cpp, Line 1274
13:21:20.546 - E: PIONEER DVD-RW DVRKD08RS : Queue again later
1:21:45 PM #25 Text 0 File Cdrdrv.cpp, Line 1274
13:21:45.671 - E: PIONEER DVD-RW DVRKD08RS : Queue again later
1:21:56 PM #26 SPTI -1064 File SCSIPassThrough.cpp, Line 215
CDB Data: 0x2A 00 00 00 03 20 00 00 20 00 00 00
Sense Code: 0x21
Sense Qual: 0x02
Buffer x09a20680: Len x10000
0x00 00 01 BA 44 00 24 B5 4C DD 01 46 FF F8 00 00
0x01 E0 07 EC 80 01 03 1E 61 02 1A A1 32 73 1C FE
0xC4 AA 67 76 92 30 DD 42 DD C7 DA 96 F7 7F 4F 42
1:21:56 PM #27 CDR -1064 File Writer.cpp, Line 306
1:21:56 PM #28 Phase 133 File dlgbrnst.cpp, Line 1767
Writing short lead-out
1:50:21 PM #29 Text 0 File DVDR.cpp, Line 3838
EndDAO: Last written address was 799 (31Fh)Close track 1, ret: 0
Close Session/Border, function 2, track: 3, finalize disc: NO, ret: 0
1:50:21 PM #30 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
1:50:21 PM #31 Text 0 File DVDPlusDualLayer.cpp, Line 1424
1:50:21 PM #32 Phase 39 File dlgbrnst.cpp, Line 1767
Burn process aborted
1:50:21 PM #33 Text 0 File SCSIPTICommands.cpp, Line 289
1:50:26 PM #34 Text 0 File Cdrdrv.cpp, Line 11243
1:50:26 PM #35 Text 0 File SCSIPTICommands.cpp, Line 452
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
rock_king_my, there are a few motherboards out there that don't use the PIO/DMA settings setup in Device Manager. I think maybe Asus is one of them. Unknown what ACER uses. But if your burner is PIO mode, you have a problem.
The symptoms will be very slow burning/reading and a lot of CPU usage during the burn as shown in Task Manager. If you don't have those problems, then maybe it's something else. I would definitely try ImgBurn and try a different brand of DVD media. The one you are using may not be compatible with your burner.
If it took 55 minutes to burn a disc then it is definitely using pio mode.
Check this link for info on how to reset dma
https://forum.videohelp.com/topic359816.html#1928559
Originally Posted by kenmoDonadagohvi (Cherokee for "Until we meet again") -
I have no idea about Visual Basics~!
But I can say that I can see "Advanced Settings" when looking at ATA/ATAPI Controllers but no "Advanced Settings" tab for my DVDWriter.
So if IMGBURN works now but NERO doesn't work (anymore like it used to), what gone wrong with my laptop/writer?
What's "Invaild Block Address" mean?
I read elsewhere that NERO 9 is trouble & we should downgrade back to NERO 7 or 8, is this true??? -
All you need to do is save that quoted text to a file "resetdma.vbs" and double click it.
Here it is already done for you.
Download and unzip this file.
resetdma.zip
Double click resetdma.vbs
That's it.Donadagohvi (Cherokee for "Until we meet again")
getting an error message "burn unsucessful. the pack queue is empty. Muxer
By Glenn VK in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2011, 18:57 -
Question about new type of Nero 6 burn error
By jimdagys in forum DVD RippingReplies: 13Last Post: 29th Jun 2009, 01:22 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Cannot burn DVDs, error message
By mataharimata in forum Authoring (DVD)Replies: 27Last Post: 22nd Mar 2008, 07:59 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 02:01
