I've spent the past couple of days trying to get an MPEG-4 with AVC codec (FourCC: avc1) - file to On2vp7 WITH Vorbis audio. I now have a few questions.
I've heard that AVI container and Vorbis audio do not work well together, can anyone provide any links as to why this is?
Is the best codec to then use MKV?
I've tried using MediaCoder to encode MKV container with the VFW set to the vp7 codec but I keep getting cannot mux audio video once the transcode is done.
I have been able to successfully export an AVI out of VirtualDub with audio off as I cannot get OGG Vorbis audio withing virtualdub, even then I dont know if I want an AVI file.
So I guess this leads me to being stuck trying to use MediaCoder with MKV as the container Flash Video as the format and VFW - vp7.dll as the "Backend" VFW.... Right?
Results 1 to 23 of 23
So I guess this leads me to being stuck trying to use MediaCoder with MKV as the container Flash Video as the format and VFW - vp7.dll as the "Backend" VFW.... Right? -
Thanks for your great reply -
I guess then since I've already exported out just the audio to OGG Vorbis using MediaEncoder - I just need to get the video into MKV - hopefully MediaEncoder will do that now that it doesn't have to worry about the audio.
What is recommended app. to mux the ogg file with the mkv file that I hopefully will get out of MediaEncoder? (and I dont believe that this app. will transcode the video at all correct?
I did download MKVtoolnix and imported my AVI file from Vdub into it but it looked like it was going to change the video file.....
I guess overall I think it will be best to get the MKV file out of MediaEncoder which I'll have to try tomorrow, I still dont see any reason why MediaEncoder cannot mux the Vorbis audio with the MKV file...ugh. -
interface was not designed to deal with that. In other words, if you try to seek
along the clip, you'll get instant loss of synchronization between video and audio.
AFAIK, there are only three "well-known" containers which support Vorbis audio
properly: MKV, OGG, and ASFRegarding OGG especifically, I don't recall whether
it supports VP7 though.
I don't use "mediaencoder", I assume that's part of mediacoder?
If you already have a vp7 in avi video (e.g from vdub), and a compliant .ogg audio file (not one generated from vfw system), mkvmerge (mkvtoolnix) will work to re-wrap both into an .mkv file. It 100% does not re-encode - it has no capacity to do such a thing -
Originally Posted by poisondeathray
Originally Posted by poisondeathray -
Originally Posted by Midzuki
I mean so I guess in the end it doesn't really matter what container the vp7 encoded file is in, right? It could be in mp4/flv/mpeg etc?? -
http://en.wikipedia.org/wiki/Comparison_of_container_formats says:
MP4 supports:
Video formats:
MPEG-1, MPEG-2, H.263, MPEG-4 ASP, VC-1, MPEG-4 AVC
Audio formats:
MPEG-1 Layers I, II, III (MP3), MPEG-2/4 (HE)-AAC, AC-3,
Vorbis (with private objectTypeIndication), Apple Lossless.
Audio in Flash Video files is usually encoded as MP3. However, audio in Flash Video files recorded from the user's microphone use the proprietary Nellymoser codec. FLV files also support uncompressed audio or ADPCM format audio. Recent versions of Flash Player 9 support AAC (HE-AAC/AAC SBR, AAC Main Profile, and AAC-LC).Codec support
* H.264
* VP6
* MPEG-4 ASP
* Sorenson H.263 -
Originally Posted by poisondeathrayOriginally Posted by tb582
How are you determining the "video bitrate" ?
If you are using a program like mediainfo, it just reads the header info. If it makes you feel better you can use a hex editor and make it a "fake" 1000000000 kbps , or even 1 kbps. It does nothing to the actual video.
The precise way is the calculate it, subtracting the audio bitrate and container overhead . The avi container and .mkv container should be different by a few kb overhead (mkv is smaller) so that might be your discrepancy
bitrate = filesize/running time
If there is a big discrepancy in your filesize (not just a few kb), then there is a problem, and something probably went wrong with the muxing - in that case mkvmerge should have spit out an error message -
If you examine with a hex editor, I am 100% sure the actual video portion of the video stream (not the junk header part) is the same in both containers.
If you use mkvextract, you will get back your original avi, but slightly smaller than the original avi, but mediainfo will read the bitrate as the same original avi (because it just reads header info, it doesn't analyze the video like a stream analyzer does) -
The hex editor is a separate tool in vdub, you don't open the mkv with vdub, you open it with the hex editor
Hex editors don't look at the true bitrate, you find the true bitrate by calculating it yourself by the formula above. Hex editor in this scenario is used to examine the raw data: If you skip to the actual video section (ignore the junk and meta data) , and you will see they are bit for bit identical (either the original avi, the mkv, or the mkv extracted avi). 100% guarantee or your money back -
ok I downloaded Neo Hex Editor - lol I have no idea what I'm looking at here, well yes I know is the binary data but I dont see anything that says bit rate is ... errr
^As I said earlier, it's NOT to measure the bitrate; I suggested using a hex editor to confirm that the data was unaltered (i.e. no re-encoding upon container swapping).
If you want more proof, or want to measure the bitrate exactly, you need to extract the raw binary file.
You can use avi-muxgui (which supports avi and mkv), right click and use "extract binary". That raw file will not have any container. Guess what, the raw file will be identical for either the avi or mkv!
Now you can measure the EXACT bitrate (even without container overhead) by using that raw file and the formula above. -
