Hi guys
I have been converting a few VCDs to watch on a PSP, using programs like PSP Video 9 and RipBot264. (Latest versions too)
For the most part, it works fine except for the last 5 - 10 minutes of each disc, where the audio will gradually go out of sync.
Has this got to do with the different sampling rate on VCDs (44.1KHz)? Or is this just a flaw on the PSP?
Any advice will be appreciated.
Thanks!![]()
Hi Baldrick, thanks for your response.
What I've noticed so far with my limited experiment is if I encode with MPEG4-ASP, the audio will go out of sync on both my PC and my PSP.
If I encode in AVC, it syncs, however, I messed up the encode to a point where my PSP is unable to support.
Sorry, I cannot provide further information without more experiment.
My PSP is currently a PSP-3006 (3000 series for Asia) with Firmware version 5.03 if that helps.
Also, I have another question. I have been doing several rips from DVD to PSP-MP4 AVC. With RipBot264, when I am customizing my rips, RipBot264 will automatically add black borders after cropping it off. I know it's as easy as just removing the command from the AviSynth window on the right. My question is, will manually adding black bars using AviSynth use up much bitrate when encoding, and thus affecting the overall video quality? Especially with movies that are in 2.39.
Thanks -
I copied out the .DAT file, rename it to .MPG and convert it from there.
Ok, thanks. I will give that a try.
Meanwhile, my other question, will adding in additional pure black bars affect the overall quality using H.264/AVC?
problem with out of sync audio with aura4you converter(mp4 PSP)
By AaronDude in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2011, 21:10 -
The sound sync is off about 30 minutes into the movie
By Genetics in forum Newbie / General discussionsReplies: 5Last Post: 20th Jul 2009, 22:26 -
video file out of sync after 20 minutes
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2009, 05:21 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 11:59 -
VCD audio out of sync on player
By burnerbie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 10th Aug 2007, 13:15
