Okej, I haave used Subtitle Workshop for quite some time now. It's a very efficient program that I like a lot. With Windows XP every thing was ok, until I upgraded to Vista 64 bit. I downloaded the lates version 4.4 for Vista it said. Now it works for some of the videos, but far from all. That is when you include (open) a video (.avi), it simply can't start it. I get the message, failed to open?????
Why does it fail now, when it hasen't before???
Is it vista again that is bothering, and if so, have can you overrun it??
	Okej I found the problem, kind of stupid by the way.
 If you just drag and drop the movie into subtitle, like I used to do before with the older version, it does not work for movies, but for subtitles it's ok
 u have to open it through the meny video->load video
 thanks any way
  subtitle workshop crashes when loading videoBy stem300 in forum SubtitleReplies: 0Last Post: 29th Dec 2011, 16:37
  Subtitle (Workshop) and mpg videoBy cyrax2006 in forum SubtitleReplies: 10Last Post: 6th Nov 2011, 15:17
  Video image on Subtitle WorkshopBy carlmart in forum SubtitleReplies: 6Last Post: 26th Sep 2011, 17:58
  Subtitle workshop help manual/videoBy triedeverything in forum SubtitleReplies: 4Last Post: 22nd Jul 2010, 05:36
  Subtitle Workshop 2.51 can't load a videoBy Charmer in forum Video ConversionReplies: 9Last Post: 17th Apr 2010, 11:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
