Hello
I record Super 8 films using a Sony (Mini) DV camcorder straight through my Pinnacle AV DV card into Magix (without passing go). I've noticed that the colours on screen and on final burn are different from those projected. Any ideas why that might be? I've heard some comments about colour depth but I dont know more than that. Thanks in advance.
Mark
looks like too many steps to me. if you are playing the super8 on a screen and using a minidv cam, why not just record it to tape, super8 is never very long. then transfer the tape to computer with windv as dvavi and work with it from there. that way you also end up with a digital tape to preserve as backup.
make sure the white balance is correct while taping the film, if not all colors will be off. -
Film Projection Issues
- Bulb type, bulb age and voltage affect color balance
- Method of light transmission (optical vs. screen)
Camera issues
- White balance as suggested.
- RGB->YCbCr .601 color space compression (saturation compression, reds especially affected)
Computer issues
- Edit stage filtering
Monitor issues
- Monitor type and calibrationRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Correcting colours in CS4
By sterankin in forum EditingReplies: 2Last Post: 6th Sep 2011, 05:24 -
Adding varying colours to subtitles?
By scifisam in forum SubtitleReplies: 4Last Post: 5th Nov 2010, 10:03 -
Colours looks bad with DVDs on my tv output
By Nitre in forum Software PlayingReplies: 3Last Post: 31st Dec 2007, 10:48 -
colours are weird?
By bennyboyt in forum Newbie / General discussionsReplies: 5Last Post: 23rd Dec 2007, 19:47 -
funny colours in quicktime
By Shaorin in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2007, 18:17
