I'm trying to set up a tv with an s-video input to use as a monitor when using the filter edit section of tmpgenc 4.0 xpress, so that I can better see how my settings actually look on a full screen crt. I'm using an nvidia 7300gt with the svga to my primary lcd display and the s-video to the tv. The only image I can get on the tv is the desktop minus all icons and toolbar.
Can I get the small window in tmpgenc to show on the crt in full screen mode ?
Thanks for any and all help !!
It sounds like you have enabled the extended desktop mode, which essentially just adds an extra screen onto the side of what you normally have. You can drag windows across to this area, and they should appear on your TV. However the flexibility of this depends on the application. If Tmpgenc doesn't allow you to drag the preview window around a separate window in it's own space then you won't be able to drag it onto the extended desktop and therefore your TV. The best you will be able to do is move the entire application screen across and work completely from the TV.
Read my blog here.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Dual DVI Displays
By Chris J Shaw in forum ComputerReplies: 9Last Post: 6th Mar 2010, 00:11 -
Dual displays: how to display same on both?
By Quimbly in forum ComputerReplies: 10Last Post: 22nd May 2008, 20:48 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
