My MKV is with subtitle. However when i use mkv2dvd converting them to vob file, the subtitle is not transfered. How to convert MKV to VOB but without subtitle loss?
Results 1 to 14 of 14
Are you talking about mkv2vob? for playback on a ps3?
Or do you want a standard dvd? Then use dvd flick or convertxtodvd, if they don't find the subs then extract the subtitles from the mkv using mkvextract first and load manually in those apps. -
Thanks for your reply. I would like my MKV to play on a standard DVD player. I used convertxtodvd to do tyhe coversion. However after the conversion ~1hrs later, i can only hear audio from my rigth speaker but not the left. Tried on the MKV file with both audio from both speaker.
What went wrong during the conversion?
Is there any software the able to do the conversion without subtitle loss in one pass? -
Hi...
What happens with AC3 5.1 audio?
The process maintain this format un vob files???
Thanx! -
Possibly. However MKV is just a container. The video and audio inside that container could be anything. If they are not compliant with the PS3 then they will have to be re-encoded. You may also find that some resolutions do not display properly in some containers.
Post a mediainfo of a one of your mkv files so we can see what you are working withRead my blog here.
Ok will try that.
But I read that mkvīs can be converted to mp4 whitout re-encoding,
and that you, after that, should be able to add srtīs to the mp4 file
and it should work in PS3. Complicated process although.
Is that true? -
Again, it depends on what's in the mkv file. An mkv can contain xvid, divx, mpeg-2, H264 etc for video, and wav, DTS, AC3, AAC, MP3, OGG etc for audio. Some of this can go into an MP4 container, some can't. And even if it can, it may not play on the PS3 anyway.
For example, I can download a 720p quicktime trailer in MOV format from the quicktime website. I can repackage that into an MP4 container that is perfectly legal. It won't play on my PS3 through. For that I need to re-encode.Read my blog here.
Again, the answer is a firm maybe. H264 video certainly works on the PS3 if encoded correctly, but not all encoding combinations will work. Again, I refer you back to exhibit B, your honour, the Quicktime trailer. Also H264 video (this time with AAC audio), and the video has to be re-encoded to play back on the PS3.
Post a mediainfo Tree output of the video in question.Read my blog here.
OK will give a try.
My goal is no re-encoding with subs.
Maybe itīs easier just to stream it?!
Best way to convert VOB to AVI or other type without any quality loss
By mikej411 in forum Video ConversionReplies: 4Last Post: 16th Nov 2011, 13:56 -
how to separate subtitle from vob or mkv in srt file
By ashe09 in forum SubtitleReplies: 5Last Post: 10th Oct 2011, 03:38 -
How to Convert MKV Files into DVD Without No Loss Quality?
By devilcoelhodog in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2009, 18:55 -
How convert MKV to VOB but without subtitle loss?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 04:55 -
True or False - It is possible to convert a VOB to an AVI w/NO quality loss
By hygieneboy in forum DVD RippingReplies: 33Last Post: 24th Dec 2008, 06:50
