Hello,
I am encoding my movies (DVD / VOB files).
I would like to use H.264 since I think it has better quality.
Which container should I use?
MP4, M4V, MKV or AVI?
What are the main differences between all of them?
And how audio and subtitles are handled by each container?
Thank You,
Miguel
It depends. How are you going to play the video later?
For computer/htpc playback would I use mkv. Open source and free container. You can easily keep the ac3 audio (even if now mp4 supports ac3 does not many converters/muxers supports it yet). -
Hi,
I will mostly use WD TV:
http://www.wdc.com/en/products/products.asp?driveid=572&language=en
What would be the best option for this?
But I might in the future see it in PlayStation 3:
http://manuals.playstation.net/document/en/ps3/current/video/filetypes.html
And in case I also want to use in PlayStation 3 what should I use?
Thanks,
Miguel -
I will be using the following:
Format: M4V
Video Codec: H.264
Framerate: Same As Source
Advanced Encoding Settings: 2 Pass Encoding (Turbo First Pass)
Avg Frame Rate: 1800 kbps
Audio Tracks: AC3
Is this ok?
Thanks,
Miguel -
Subtitles that can be turned on or off and are not directly rendered onto the video stream.Originally Posted by shapper
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
How to easily convert a Blu-ray to MP4/M4V/MKV using free tools
By Baldrick in forum User guidesReplies: 18Last Post: 29th Mar 2018, 02:20 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Converting MKV to MP4 (m4v) for iPod Touch with ASS subtitles [HELP]
By The_Jelly in forum Video ConversionReplies: 3Last Post: 14th Jan 2010, 00:17 -
m4v > avi or mp4
By empershand in forum ffmpegX general discussionReplies: 2Last Post: 17th Mar 2008, 15:55
