  1. Member midders's Avatar
    Sep 2008
    Hi there
    Most of my DivX/Xvid files playback fine, but when I try and play one file (MediaInfo below), the video is squashed vertically with black bars at the top and bottom of my 16:9 widescreen TV.
    I've tried resetting the display and pixel aspect ratio with MPEG4Modifier with no effect. Is there anything else that I can do without re-encoding? And, if not, then what do I need to change to fix this problem and what's the (free) application of choice for re-encoding Xvid?
    Sláinte
    midders
    Hardware:
    - Denon DVD-1930 (supports DivX files up to version 6)
    - Sony Bravia 16:9 widescreen TV
    MediaInfo output:
    General
    Complete name : episode1.avi
    Format : AVI
    File size : 350 MiB
    Duration : 44mn 18s
    Overal bit rate : 1104 Kbps
    Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
    Writing library : VirtualDubMod build 2178/release
    Video
    Format : MPEG-4 Visual
    Format profile : Streaming Video@L1
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default
    Muxing mode : Packet Bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 44mn 18s
    Bit rate : 974 Kbps
    Width : 640 pixels
    Height : 368 pixels
    Display aspect ratio : 16/9
    Frame rate : 25.000 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.165
    Stream size : 309 MiB
    Writing library : XviD 1.1.0 (UTC 2005-11-22)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 44mn 18s
    Bit rate mode : Variable
    Bit rate : 117 Kbps
    Minimum bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 37.1 MiB
    Writing library : LAME3.97b
    Encoding settings : ABR
  2. Member midders's Avatar
    Sep 2008
    Since posting I've found that resizing to 720x576 using AVI Recomp 1.4.5 gives the correct aspect ratio on playback. However; it does take ages and I have 5 series to process, so any other ideas still appreciated.
    Sláinte
    midders
    I guess you tried to set the aspect ratio pixel AR to square pixels in mpeg4modifier and checked if you have any aspect ratio settings in your dvd player settings?
  4. Member midders's Avatar
    Sep 2008
    Originally Posted by Baldrick
    I guess you tried to set the aspect ratio pixel AR to square pixels in mpeg4modifier...
    Yes, tried that; see first post.
    ...and checked if you have any aspect ratio settings in your dvd player settings?
    I thought I'd played with every option on the unit, but your comment made me double check and it turns out that I'd missed the up-scaling setting which can only be set by a physical switch on the player, and not via a menu.
    I tried it on every setting and found that the correct aspect ratio is only displayed in the 480p/576p mode.
    Thanks for the prompt.
    Sláinte
    midders
