Hi!
Ive been using Protools for several years and recently started with filmediting. Im editing in Final Cut and have just cut my first film almost done and want to start to edit the sound in ProTools. The problem is that I hoped it in my imagination that it would be possible to
1) cut the video in Final Cut,
2) import everything into protools.
3) Cut the audio in Pro Tools with the possibility of viewing the video as well
4) export everything back into final cut.
is this possible in some way? havnt looked som close yet but seems to be possible to this thing in soundtrack pro
how do I manage to do this in the best way? I would like to use protools because ive used it a lot and like the program
Per
The Majority of us roundtrip
( that is the techinical term for what you are trying to achieve)
from FCP to Soundtrack Pro and back.
Yes, you can preview the film in Soundtrack Pro as you score it;
once done you can then export your audio back into FCP and then
finalize your film to final delivery format.
Since I don't use ProTools, I can't comment on the possiblity
of using it in place of Soundtrack Pro, however, you might try
asking your question here."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 09:35 -
Protools to final cut - what soundlevel
By perik in forum AudioReplies: 0Last Post: 4th Aug 2009, 10:46 -
Final Cut Express- How To
By ker-plop in forum MacReplies: 2Last Post: 8th Apr 2008, 20:41 -
Just Got Final Cut Pro 6
By The Monkees in forum MacReplies: 3Last Post: 14th Nov 2007, 13:24 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
