  1. Are there any free programs to print DVD covers, I am using NEATO program but the covers dont come out full size.
  2. pwygant where did U find DVD covers in CoverXP??
    I couldnīt see any Just the CD Tray sized
    Jul 2001
    Brazil
    I use BOND s Cover Print software (freeware). Simple and works fine.
    On the soft choose DVD and make and save your configuration: I use Height: 18 and Width: 13.
    Dowload : official CoverPrint Website: http://www.cdbond.com
    Bye
  4. I print dvd covers too, and there is one thing i found, you can't print the whole cover with certain printers. I have to take the cover, cut out the front and spine label, print it. Then print just the back. You can attach them, but they stay in place even if you don't. I personally use paint shop pro, measure how tall the label should be, then input that as my hight in page setup and then click keep aspect ratio(or something like that, I dont' remember off hand.)
    Jul 2001
    Brazil
    Adding: (about BOND s Cover Print software (freeware).
    Also see : http://www.greger.nu/greger_coverprintlink-sv.htm
    Bye
