I recently accuired a video camera (SVC T-100) and it records in HD at a res. of 1280 x 720 in what i believe is the H.264 format. I downloaded the files to my computer and then had to download Ffdshow codec to view them. Works great!!! What i need to know is if there a freeware program that will allow me to edit and create my clips with menus, chapters, credits and music, then burn them to a single layer DVD+R and keep the aspect ratio at 16:9 like WinDVD creator did for my older 640 X 480 mpg clips. I do not have a dual layer burner yet and want to know if this is possible. I realise that my DVDs may be of shorter length but that is not a problem for me. Thanks for any advice anyone can give me in this field
Tim
	I doubt you will find a freeware that supports all that. You can use all-in-one dvd converters like dvd flick and favc but they have limited editing and menu capabilities.
 You could use several free programs to accomplish most stuff like basic editing using avidemux, converting using hcencoder and authoring using gui for dvd author.
 If you are willing to buy an app I would try tmpgenc authoring works.
	Well after using WinDVD Creator 2.0 i got satisfactory results except that on my 16:9 screen i had bars on the side and top and bottom. If i wide zoom the screen then it fits perfictly but i lose picture quality.
 Will tmpgenc authoring works create the movie, menus and chapters without the borders and fit the 16:9 screen without resizing the picture. I am not to crazy about using several different programs yet. I would like to keep it simple for now. Thanks
  Need help ripping VHS footage from DVDs, then re-authoring them on one DVDBy Condor Joe in forum DVD RippingReplies: 8Last Post: 24th Aug 2011, 19:29
  Converting Dual Layer DVDs to AVI (Video Footage More Than 2 Hours)By cucuzza in forum Video ConversionReplies: 2Last Post: 17th Sep 2010, 19:54
  Producing DVDs from HDV footageBy lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 18:25
  new to making home videos, canburn to DVD but NOT as one movie ! ??By DoktorDave06 in forum Newbie / General discussionsReplies: 9Last Post: 10th Feb 2009, 14:25
  15hours of footage on 2 DVDs possible?By itsme1 in forum Newbie / General discussionsReplies: 45Last Post: 19th Jul 2007, 17:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
