Hello all,
I have just recorded a movie from my reciever to usb stick and it is saved as .ts file
i tried vlc player but did not work ! is there a way to open it ?
thank you
Results 1 to 11 of 11
Try also smplayer and Media Player Classic.
If it still wont work then give us the details from the ts, use MediaInfo, open the ts, change to View->Text and copy and paste the information in this topic. -
Thanks Smplayer works greatOriginally Posted by Baldrick
i wonder how to convert .ts to dvd i already tried ulead but says file format not recognized
thank you -
Try ConvertXtoDVD. Or the free FAVC or DVD Flick might work.
i would use sm or mpchc. but if it is h.264 or avchd i choose mirillis splash. new player from mirillis. this is continuation of oxygen avchd player i think coz looks the same, but plays h.264/avchd much faster than old oxygen. it is also faster than vlc and ffdshow,Originally Posted by jagabo
but it doesnt support mpeg-2 yet.
edit: oxygen avchd player was available at videohelp but after project stopped it was removed i think. splash is not on videohelp yet so use google. -
you may have been able to simply rename it m2t which plays in wmp
hi guys
can someone help me ???
i have a little problem !!!
i use a capture card that captured streams as .ts extension
i want to use these files on adobe premiere pro or canopus edius software
but for example in premiere the audio for .ts files didnt imported (software didnt generate it )
how can i solve this problem ??
i dont want to convert the .ts because it is too time consuming !!!
thANKS
$d@
How Do I Play Raw DV Stream Files on a TV?
By NY2LA in forum Software PlayingReplies: 97Last Post: 30th Jul 2011, 00:21 -
DivX Plus HD - Unable to play stream videos through WebPlayer
By wtopace in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2009, 14:49 -
Question why new software causes Windows Media to not play stream
By jimdagys in forum ComputerReplies: 1Last Post: 21st Sep 2009, 19:41 -
Do you stream your media or play it locally on a physical device?
By yoda313 in forum PollsReplies: 15Last Post: 19th Jun 2009, 22:03 -
Some WMV files won't stream, but play fine if downloaded
By DVantrease in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2008, 14:49
