I have a DVD of a compilation of some old film footage. It's just a straight recording. I just want to take the instances of footage and isolate them and have them as individual VOBs. It doesn't matter whether these VOBs will be able to be burned onto DVDs or not. I just want to isolate the footage and have it as 3 unique VOB files. No further compressing or anything like that, either. So, can anyone help me?
Also, I need frame-by-frame editting power. I began this project with DVD Shrink and found out that DVD shrink only lets you go 14 frames by 14 frames...
DVD Shrink lets you edit on key frames ("I" frames) only. These can be anywhere from 12 - 18 frames apart depending on the disc in question.
DVD Shrink is a simple way to get your VOB sets. You can then either use VOBMerge to create large VOBs, or VOB2MPG to create mpg files. Either way there is no quality change.
For frame by frame editing, the two best tools are VideoRedo and Womble Mpeg Video Wizard. VideoRedo is a virtualdub-like assemble editor. It is simple, quick, and great for chopping out sections, such as commercials.
Video Wizard (Womble) if more like a Non-Linear Editor in that you can cut a clip up, re-arrange the parts, add music, add titles etc. It is no competition for something like Vegas, but it is mpeg-native.
Either of these will edit without re-encoding (caveat : if you change the video in any other way - titles, filters etc - then it will get re-encoded)Read my blog here.
Isolate voice in 6 channel audio clip
By basterd in forum AudioReplies: 7Last Post: 11th Feb 2012, 10:31 -
Extract / isolate 5.1 audio tracks from DVD
By soundchaser in forum MacReplies: 0Last Post: 16th Mar 2009, 13:21 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 05:14 -
Two instances of FFmpeg
By ism33 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Nov 2008, 16:13 -
Removing all info from dvd/vobs, but leave raw footage to edit?
By snek11 in forum Authoring (DVD)Replies: 2Last Post: 20th Jun 2008, 10:15
