I have a divx movie that plays fine in media player. However when I convert with tmpeg to mpeg, the audio is out of sync!
DivX specs: 25 fps 640x352 Sound 128 Kbps 44100 Khz
I use the PAL-template in TMpeg but it still delays the audio.
I have tried VirtiualDub to make a seperat Wav. file and used it in TMpeg as a audiosource - but still without any luck. The sound is still delayed by 2 sec.
any suggestions ??
Try and use avi2vcd it works great for me when i get the same prob... also the new tmpgenc 2.52 works great??/...... digital digest has help as well for out of sync audio
make sure that you use the 3:2 pulldown to keep the correct aspec ratio for a cleaner movie with no distortion -
When you use AVI2VCD you use the decompress.exe file right? That gives you an .avi that you put in for BOTH the audio and video in TMPG?
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 15:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 03:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 01:23 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 23:28 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 21:29
