I'm able to capture high-def HBO movies recorded on my DCT-3416 using the procedure below (MacBookPro and Firewire-SDK):
http://jpicune.wordpress.com/2006/10/13/record-shows-from-your-comcast-hd-dvr-onto-your-mac/
However, the resulting m2t file only shows two audio channels in properties. I should get six channels.
1. I'm now doubting that the DCT3416 is *really* outputting 6-channel audio. How can I verify this? I connect the DVR optical out to my AV Receiver and HDMI to my Plasma.
2. Has anyone else used the same procedure and was able to capture 6-channel audio?
Thanks in advance,
ShredrCA
Just be happy you get any HBO capture over Firewire from cable. For most of us HBO is 5c blocked. You could always attempt audio digital or analog capture off the S/PDIF port. It will probably be out of sync with firewire video. That will require editing.Originally Posted by shredrcaRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
weird format: .dct
By one post wonder in forum Video ConversionReplies: 7Last Post: 28th Mar 2011, 08:16 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 16:28 -
Problem firewire capturing with DCH-3416 TS files length
By Zone3 in forum Capturing and VCRReplies: 0Last Post: 13th Dec 2009, 20:04 -
Live streaming on Comcast 3416
By coolmike711 in forum Capturing and VCRReplies: 0Last Post: 11th Sep 2008, 12:51 -
Seperating Audio Channels.
By vodmare in forum AudioReplies: 7Last Post: 14th May 2007, 17:33
