After remuxing a movie with 2 sub streams, I was repositioning them (and re-doing the color which had changed) with Dvdsubedit. I didn't realize I should switch the preview to Letterbox, so I was manually changing the vertical distance (sometimes clicking "All modifications to all streams" when it looked right). I don't know if those changes might have anything to do with this problem, but the text looked fine up to this point
I figured out I had to change the preview window to properly align the text vertically; I used the vertical boundaries to raise the subs to the correct level. However, as I did this, I could see some subs in both streams have the tops slightly cut off, and this bit of sub is shunted (vertically) underneath the text. Played a sample and the cut-off text also vibrates slightly, too (like the dvd player is having a problem with it). Any way to fix this? Adjusting the vertical now doesn't change it, nor does adjusting the individual CLUT.
Results 1 to 1 of 1
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 17:36 -
Subs in the top and bottom of screnn at same time. (How)
By X_Splinter in forum SubtitleReplies: 4Last Post: 29th Apr 2008, 19:58 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55 -
What Tool: Type in subs while viewing subs from hardcoded video
By kpic in forum SubtitleReplies: 3Last Post: 6th Jun 2007, 20:29
