Closed Thread
    Jul 2003
    Germany
    My MKV file is with subtitle. However when i use mkv2dvd converting them to vob file, the subtitle is not transfered. How convert MKV to VOB but without subtitle loss?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    I'm not sure if its the same program but have you tried mkv2vob? It may have a better subtitle utility.
    Also you can search the forum for methods of inserting subtitles into vob files. As I don't do much work with subtitles I don't have much direct experience to offer.
    edit - also if you are planning on actually creating a normal dvd with the vob you can extract the subtitles from the mkv and then insert them with a dvd authoring program that imports subtitles. I think there is something like mkvextractor or some such program for doing that.
    Please don't cross post. ONE topic is enough. https://forum.videohelp.com/topic366194.html
